£280 To Do A Head Gasket?!
They must be having a turkish... And they told me they need to replace the cam-belt, whether or not it's less than 4 months old ¬__¬
Anyone fancy a job? :lol:
  • Replies 20
  • Views 1.2k
Seems a reasonable price, i paid £330 a few years back for it on my GT.
As a cambelt costs under a £10 what are you crying about?
Do you wan't them to do it for free or something ?
My friend did his head gasket on a Vectra V6 engine on his driveway with minimal tools, and he's not a mechanic...if you just use your head...
You'd be daft not to replace cambelt/waterpump while the head is coming off IMO
Edited by pettsy
Not fussed about the price of the belt, just seems odd why it needs to be done when it's only done 3000 miles.
well you imagine if a garage does your headgasket, and the belt you say youve replaced 3k miles ago snaps and fucks your valves up.
are you going to blame your 3k old belt or the garage?
anyone with sense would replace the belt while its off as its usually thier back on the line rebuilding the engine for a customer
edit: and as pettsy says its wise to do the water pump on a polo, as if it needs changing its a cambelt off job. on mk1 golfs and the like its easier as the waterpump is completely seperate from the cambelt, but the water pump on the polos in turn is also the tensioner for the cambelt.
Edited by grungeisdead
Just think about the hours it would take.......& i presume they would warranty the work???
Main stealer or back street garage???
Back street. I guess the only reason I posted this mini rant is although I now see that £280 is fair for that job, I have no money and it kinda came as a shock to me... I presumed it would be standard rate @ 2 hours or so + £10 gasket. How wrong I was XD
That seems a lot to me.
Does it include a head skim? That's the expensive bit normally.
Ask them how much without the parts and see if you can get it any cheaper (unlikely as they get trade prices but worth a try).
Got to get mine done before I go to Germany, but I know a good cheap garage so hoping it wont be as much of a shock as that.
That is a fair price tbh. And a head skim is usually around £30 so not really that expensive. Just the labour that is the stinger.
i think its a fair price to be honest mate. quite a few hours of taking it apart, and putting it back together. might as well do the belt too, not critical, but as it wont take any longer, for the sake of a tenner.
I think i'll shop around :-) I want it done for peace of mind and like B-shaw, I do plan to take it abroad and it's just something I could do without worrying about
They're fairly straightforward to do, but it's still a day's work. So yeah, that's a fair price.
Otherwise, you can DIY it for about £60 inc a head skim.
I have pretty much no confidence in my engine capabilities... If anyone has done a start-finish guide on how to do this I'd give it a whirl though :-D
Haynes :thumbsup:
Haynes shows a good guide on cylinder head removal + refitting, not sure if it would be sufficient though, I am a self confessed nonce when it comes to mechanics
It cost me £70 for parts: Headgasket set inc all the gaskets/seals and headbolts, oil, oil filter, air filter, cambelt, and fuel filter. The head skim cost £25 and i already had a waterpump. And i bought my self a tin of hammerite. So for £100 i was well happy. Took me a few extra hours because of cleaning/painting everything which made it a weekend job.
Think how much they are charging for labour and VAT.
shame you're so far away i usually charge £80 for 8v headgasket, or £120 for 16v. it's easier to do the belt/pump while the head is of so would only be £20 on top. this are labour only figures.
seems a pretty fair price tbh. my sister had hers done on her squareback by a local mechanic at almost £600!
when my headgasket went a couple of years later me and my dad fixed mine up, cost around £80 for all the bits... a few evenings work and it was done.
my mechanic would also recommend a head overhaul while its off - about £130 at a machine shop.
but any mechanic will be £30+ an hour - so even if without skimming its about £70-80 in parts if not more + labour
