Mk2 Indicator Problem
HELP! Has anyone has the same problem I'm having. The Hazard warning light switch I think has caused my indicators to stop working. The hazards work, and the parking lights work with the indicator stalk down either left or right, however when I indicate left or right I have nothing, no clicking from the relay (which I have changed) and no exterior lights only the dash green light. Also the dash green light stays on dim too
Can anyone help I thinks a faulty hazard switch
  • 1 year later...
  • Views 1.4k
hey I'm having the exact same problem on my car have you found a soulution ?
I Not sure but have you checked your relay?
I had a similar problem, my indictors would work but not flash, (one solid light). Turns out the earth wire connected to the rear bulb holders was loose and shorting the system. Anyway, worth a try!!! :lol:
  • 12 years later...
What was the fix? I’m having the exact same issue on my mk2 loon
