16v Foglights
hey, I'm putting a 16v front bumper with foglights onto my p reg 1.0L polo. I've already replaced the standard switch with the foglight switch inside but are the connections for the foglights there behind the bumper or will i have to wire them in? cheers x
  • Views 971
You'll have to wire them in.
And it's quite a b*ll ache to do!
I did it on my 16V which came without fogs, and the wiring is tricky to get back into the car - I came through the passenger footwell in the end, and also be careful with the switch - I ended up wiring in a separate switch to make it easier.
Were did you get them from
