Polo Engines And Spec Help
Hi there, I've recently been offered a mk3 polo 1.3 as a run about instead of using my mk2 golf gti all the time for work.
I was just wandering what all the specs are of the mk3 polo's.
Weight
Power
models and engine sizes
MPG
etc etc.
Any help is much appreciated.
And I'm sure if i do get one as a run about, i will end up doing a few little bits and pieces to the appearance mainly, and considering I'm planning on a vr6 conversion for my mk2 golf, i will have the 1.8 8v engine sitting about......................so may go in the polo.
Thanks, Luke
  • Replies 13
  • Views 2.3k
iv allways wondered what a standard mk3 coupe weighs.
this site doesnt give it. Does anyone know what a mk3 coupe weighs ? lol
The G40 is quoted as being 830kgs. I should imagine other models being devoid of the supercharger and intercooler, etc might be around 800kgs.
As for the 1.8 idea. Its by all means do-able, but it won't like corners! The early Polos have the most flawed and basic of suspension set-ups upfront as standard, and need a bit of cash throwing at them to be able to take corners competantly. Adding a fair bit of weight upfront might further compound the flawed handling dynamics.
Yeh i wouldnt be leaving the whole car standard if i swapped the engine, suspension would be one of the first things i sort out before hand, already got spare alloys to go on.
Jus seeing how things go now, as I've been offered 2 more jobs now on top of my full time work.
L
Hey man,
Any idea what the year is?
http://www.parkers.co.uk/cars/specs/Models.aspx?manu=12243
If you click that link above and select the appropriate model then you'll have loads of specs and useful info,
Dan
I dont know the year as it has a private plate on \t the moment.
L
Haynes manual states kerb weight as 765 - 830kg. IIRC the breadvan (aka hatchback or squareback) is the lightest, the coupe is somewhere in the middle, then the saloon is heaviest. G40 versions will prob be heavier than NA versions due to extra components.
get the 1.8 engine conversion out of your head! as said its do-able, but is ALOT of work and just not worth it really, the sump will be to close to the floor, will be fronty end heavy, need to modify the chassis legs loads, brake master cylinder is in the way, and wouldnt be much better performance than a gt conversion which is so easy its childsplay!
Hi guys, new to club polo. Just signed up. I've got a mk2f/3 breadvan and its apparently 1230 kilograms. Some quotes of 800 or so seem a bit unlikely? Engine is a 1.3 CL producing around 55bhp I believe, hope this helps. 0-60 official figure is 14.5 seconds I think.
Edited by Polo Will
That'll be maximum gross weight (ie when it's full of people/stuff). The figures I quoted are when it's empty (apart from fluids, fuel, etc, natch).
Wht engine is the GT sorry?
Not familar with the polo engine at all.
L
L
Code 3F, 1272cc, multi-point injection, puts out around 75bhp. With a few mods (air intake, AFM, exhaust manifold, cam, chip) will make 100bhp.
Or if you have some spare cash, buy a G40 engine. Code PY, 1272cc multi point injection supercharged. Can be tuned to 200bhp+ from 113bhp standard.
I would love the g40 engine for it, but using the car as a run around, i may aswel keep using my mk2 golf gti all day everyday.
The GT engine may be better suited for what i plan on using it for. Thanks for info steveeeee :)
Ill have to see if i even bother getting the polo in the first place, people always offering me run arounds, just the polo had been well looked after by a bloke i know.
L
Edited by mk2gti_houch7
