Weller Wheels On A Mk3 Square
How much arch work would be needed to run a mk3 square on 13x7 weller steels et7 running 175/50's? i want it fairly low, about 60mm rear i think
I suspect too much as in a bit of surgery that could easily look shit.
Put it this way 7J ats Classics et20 need the inner lip rolled with the arch pushed out an inch (by someone who knows what there doing).
This is a pure bugbear of mine because people are assuming they can strap anything on to a mk2/mk3 breadvan or a coupe for that matter with silly offsets. Then they either get a completely unrealistic photo chop done and folk are like "that's cool do it". Then they attempt to fit the wheels and mess the arch up and in some cases bugger the car completely. I've done a welding night class and done a fair bit of welding now on my own car and I still wouldn't mess with the rear arch of a square. There's a thread on here and the gallery section where I personally think the guy has made a mess of the car but I don't want to come across as the boring old fart purist (if you know what I mean)
Don't get me wrong you learn from mistakes and there's nothing wrong with enthusiasm but I hate seeing perfectly solid cars getting ruined.
Good luck with this anyway I do like those white wheels on your GT but you've obviously done your homework with the right tires etc.
cheers for the advice, i've never owned a square so am not really sure to the in's and out's of them. I was just seeing if it was possible as the possibility of it determines wether or not i get one. I had thought about a rear arch conversion, i read a thread on a red mk2 square that had had this done, but ruled it out due to the amount of work involved.
dont let that stop u getting a mk3 breddy, they are wicked........ i should know :)
nothing is impossible..........
I'm in the same situation as you mate, i have a mk2 breadvan
and it's difficult to get 2nd hand rims that fits it with that stupid arch (I'm too tight to buy them new :p)
but this shouldn't put you off buying it, amazing car man, trust me :]
Alex.
if you want poke then you will need arch modds , but if not 14" and 15" 6js go on with the right tyres with no modds or some times a little lip trimming , heres one of my old ones on 14" with 80mm drop
sorry about picture , its a pic of a pic :-(
