Bad Times...
So....decided to try fit my Newman Cam today. Took belt cover off, turned it over to TDC then noticed that my 5000mile old belt had lots of teeth missing... Decided to put it back together and drive it to my mates garage so he could have a look at it, and when i started it up...tap tap tap tap tap tap... :-o
Like a prat, I turned the engine to TDC using the cam sprocket, rather than the crank one,,,therefore some valves said hello to so,e pistons...! So spent all of the afternoon stripping the head off!
Trying to look at the positives though: engines now just done 100k, and she'll be getting all new gaskets, de-coking, and relapping of valves, and new cambelt, so all isn't too bad.
Edited by Wiggy
  • Replies 47
  • Views 4.8k
How did you manage to do that if everything was marked up?
I think I'm just about out of my shit storm, Make sure you get new guides and seals!
Oh Wiggyyy :cry:
oh dear! looking at positives tho its a good excuse for an engine recon
Yeah, i'm trying to look at the positives. Spent this morning stripping and cleaning the head, valves don't look bent, but i filled the portd up with water when they were still in the head and there was some seepage there... :-(
Picking up H/G set and head bolts from GSF tomorrow, but not having much luck finding valves...GSF's website list exhaust valves, but only list inlet valves for spi's...am i right in thinking that the valves/heads on all mk3's, except G40's, are the same? They have valves for AAV, AAU and AEV engines from '92 onwards (my car is a 91 GT) Would those valves be suitable?
EDIT: Just been reading about on the forum, found out that the AAV valves (1.3) should be the same, but the stems are thicker on earlier models, would that mean that the AAV valves from GSF would be no good as they would be too small, or is there a way round that, such as with bigger oil seals perhaps? Need to know ASAP :-)
Edited by Wiggy
silly boy...
Take a valve in with you to show them, thats what i did after they gave me the wrong valve stem seals that way you know there right.
The AAU (1.0) inlet valves are smaller iirc but the AAV ones are the same, You should be okay if you get AAV valves for a 91 engine but just check when you go in to save messing around.
When you say its leaking, where from? Might get away with just a relap?
I was told if you roll a valve on a table you can see if its bent or not.
Edited by carver
wiggy!!!
your engines now foo-barred, sell me the cam!! lol
Edited by Oily Fingers
Aye, the plan is to take a couple valves in to GSF tomorrow to make sure they are right. The price they gave me for the inlets was one i couldn't see on the website, so i wondered if they didn't list them as they were the less common, bigger ones...? But yeh, so if they are too small, then looks like i'll have to try find a 1.3 head.
And Joel: get your own! Mines still going in, although now with a de-coking, new valves and a slightly skimmed head...mua ha ha ha ha!
I hate Norwich GSF...!! Whoever the hell decided that it would be a good idea to close early on the day that would logically be the busiest for retail customers needs shot.
Soooooooooooo looks like i've got to wait til monday now before I can find out if the valves they've ordered me are the right ones. Gaaaay.
wiggy you gooon!
Jeez dude, that's unlucky. love your GT though, gonna be good to see what its like with a recon!
Aye, I can't wait to get it back on the road. Had to borrow my dads Almera the last 2 night for work, oh my god how soul-less can a car be? Although sloppy suspension + ditchfinders makes for some interesting cornering activities... :unibrow:
Woo, picked the exhaust valves up today, and they are the right size. Got to go back and get the inlet valves tomorrow, hopefullly they'll be the right ones... Also got the H/G set and H/bolts, so things are looking good...
Assuming there's no piston damage, just get a head off a scrapper.
gee wizz :-(
Finally! Everythings ready for me to put back together! Phoned GSF yestreday and they said the inlet valves hadn't left heathrow yet due to the snow, so manage to sponge a lift there this morning, got there to find that they had sent up 2 correct valves, and 2 wrong ones!
So, came back and lapped in the 2 good ones whilst waiting for 2 more to be sent in from elsewhere, went and picked them up at 3, and finally got the head back topgether by 5.30, so just gotta buy some coolant tomorrow, fit the head, pick up the inner cambelt cover from VW, put the belt on, and hope for the best!
How long should i run her in for, considering she'll have new H/G, valves and camshaft? And how much water should the coolant system hold? I had a look in the Haynes, but it doesn't say....which i thought was odd.
dude i should have thaugh I've got loads of valves here from 1.3 hyrdalics head and 1.4 golf head which are the same as gt's iirc u could ahve had them for nothin.and i could of delivered em.if you still need em pm me..
500/1000 miles.. should be longenough... but on a short once u put a full tank of fuel in 2/3 times you should be good to start giving it a bit of stick....
what coolant you putting in???? i would advise putting prestone.. as it universal.. and will rejuvinate any seals and rubbers that are going!!!
D'oh! Lol, nevermind, got all the new valves in ow, so not needed, but cheers anyway!
As for coolant, was gonna just buy whatever i can find on the way to my mates tomorro and put that in for the first, say 500 miles, then change it and the oil for some decent stuff. I think i'll buy 5L if i can, as that should be plenty.....maybe...
Get the g12+ from GSF mate, you need about 3.5l i think i usually put 2.5l in. I think the whole system holds 5l iirc
yeah 5l's will be plenty of coolant mate, just brim it, run it up with the cap till all bled etc then correct the level afterwards.
Just make sure you dont do it again lol, wind it over plenty of times before starting and triple check it all lol
remember clockwise from the crankshaft, hopefully that all goes without saying though mate. should go nicely with the cam!
Edited by drewbar
Yeh, lol defo gonna turn it over a few times by hand at the CRANK before i start it! Now i know how i fucked it, it seems so obbvious, and i feel a little bit retarded, but at least i'll never do it again! Wish me luck y'all!
mate we all fuck up sometimes dw! goodluck
Fuck sake! Long story short - car is now back together and driveable, but the engines really rattly. Also, even after i got let it run until the fan came on, when i checked the oil filler cap, it was all mayo-ish. I've just about given up hope with the car now. I think i'll run it for about 50 miles, keeping an eye on the water level, and hope that things get better.
