Rear End De-badge.
okay, here's the deal...
i want to debadge the rear of my mk3 square...
i have removed the badge, and am left with the recess.
now, i've never done anything like this before, so i'm just looking for a bit of advice before i continue and make any rookie errors.
i plan on using filler to plump it back up to being level with the rest of the body.
and then spraying it.
BUT.......
i need help on two things:
1. never used filler before, so, any tips?
2. what would be the best way to spray it... would a halfords colour match do the job?
  • Replies 8
  • Views 1.4k
ok here goes
first you need to take off all the paint in and around the recess because filler does not stick to paint! it will end up cracking
using a hammer, tap the step of the recess in, just a little so the step is reduced, this so the filler can feather properly
mix up the filler as directed on the tin (about 1 egg cup of filler to 1 pea of hardener)
fill the recess and the surrounding area of about 2-3cm
once dry sand and fill again accordingly
once filled area is flush prime and paint
ah cheers i didnt even think about taking the paint off...
when you say tap the step of the recess in do you mean like flatten it out a bit??
like this:
or just making it a bit more lumpy?
would halfords colour match blend in perfectly do you think?
Filler,through time will crack mate.You should really
get someone to weld a small patch over the recess
then fill,prime and paint it.
The colour wouldn't be perfect because the colour of your car would of faded, Halfords sell Alpine white off the shelf so buy some and spray on an inconspicuous area first.
A good T-cut will make i look better aswell
Good luck
hmmm, i'm not certain on the welding business... i mean, if the weld goes wrong i'm buggered, at least with filler i sort of have a second chance.
i know halfords sell alpine white, but my car is 17 this year... so over the years the paint will undoubtedly faded, i just hope a halfords colour match would do the job to a tee.
sorry if i have been tought differently to u all but , DONT FILL IT TOTALY WITH FILLER it will swel and crack , u need to weld a plate inside the resses and grind flat , if u dont have a welder i used to use a small hameright tin lid and screw it is so the filler is only less then 5 mm thick , if u are doing a halfords spray job blend it in then t cut it , if u are local to mids bring it to me i stil have alpine white and will spray it properly for free
not quite so dramatic as that!
yea maybe just make alot of little dents in the edge
if done properly the filler will not crack, i have 11 years of panel beating experiance and have done alot of flushing
welding a plate is an idea althouh if its not done right you will find there will be a lot of heat distortion and you will end up chasing the dents made by the distortion thus using a shed load more filler!!!
plates are used on holes like handles, locks etc
you could use fiberfill first and then filler if you want as its stronger
after its complete
rough the paint on the surrounding area about 30cm each side with a scotch pad
prime (about 6 dry coats) then wet and dry
paint several even coats, again dry coats
its good to use a heat gun or hair dryer before and after each coat, this reduces the chance of aerosol paint running
when totally dry (allow about 24hrs with aerosol) use a cuttung compound to polish (G3 is good for this)
stand back and admire your work!!
thanks polower that's a top guide, i'll be sure to print it off haha!! and i'll post some pictures when I'm on with it.
i dont fancy doing and welding on the bodywork... at least not on that prominent spot on the car.
i'll use fiberfill then, as i dont want to risk any cracking, and i'll try keep the filler usage to a minimum if cracking is a common problem.
good painting tips too. :) thanks guys. any more tips/previous experience of this sort of task welcome :)
i love this forum lol, come on at half eleven and still get some great advice!! cheers.
