Mk3 Interior Door Handle - Broke!
Yestarday my inside driver door handle broke right off when i try to pull my door closed, anyone had any experience with putting it back on? I'm currently using a pair of plyers to pull the steel rod to open my door :x.
  • Views 881
if you have some spare time on a nice day i'd suggest taking the door card out and seeing if there's an internal fault somewhere...
has the whole of the handle been pulled out of the door card or just the lever part?
As the handle is plastic, if its broken off then youll probably need another one from a scrappy
Wouldnt think itll glue
As posted, get the door card off to see
Dont damage the door membrane or youll end up with water leaks
hey guys cheers for advice - its the lever part of the handle which has came off, the rest of the mechanism seems otherwise intact. The handle itself has what can only be described as two 'hooks' (top and bottom) which i think fix onto the door itself and a circular hole (near the centre) were as the metal wire hooks onto to manage the 'pull' system to open the door. Would i be better taking the inner door off to fix it do you think? I thought this out but thought the problem would be fitting the handle back as it were from the inside would be a problem. There doesnt seem to be any of the plastics missing from it. Just dont want to start ripping my door apart and end up breaking something - id prefer to keep using my trusty plyers to open i think if thats the case haha.
just find another handle from the scrappy and hook it back on, it's sometimes a bit temperamental to go back in when it's hooked on to the metal rod but it shouldn't take you more than 5 minutes.
just looked at it there on my break (I'm in work) and seen what needs done, the part where the bottom of the handle joins to the door has broken off has snapped off (just a small square bit of plastic) ill try melt on a bit off plastic tonight, if all fails ill need to get a whole new bit where the handle connects to the door :(! any other tips would be great, thanks for the help guys!
