Removing Tint Sray
Whats generally the easiest way to remove tint spray?
  • Views 1.2k
I reckon turps or nail varnish remover are good bet!
And as there sold in plastic bottles they're unliklely to burn through anything else.
turps wont remove the paint and nailvarnish remover will melt the plastic and totally knacker the lights either use the correct removing spray or use t cut, t cut removes it but takes longer but does not knacker lights
thanks for the replies guys, there not to dark but would like to return them back to standard, i will try t-cut tomorro and nail varnish remover, i will update this topic when its done!
how will it melt the plastic if there sold in plastic bottles??
different types of plastic, test it on a small aree afirst if using nail varnish remover
Petrol will do the job.
i tryed t-cut, but it didnt seem to work, in the end i used nail varnish remover, i used it on my side repeaters
you need to soak the tinted area in nail varnish remover, then the tint will just rub off, but if you are planning on doing this dont rub the plastic underneath it because I'm sure it would damage it,
also took me around two hours, just to do two side repeaters, but would have took around 30 mins if i had of soaked the whole lense, i will update when i have done my rear lights!
