Earth Wire Connecting To Amp...
I re-wired my amp a couple of weeks ago after the wire came from the earth and I had to replace it. But now the wire from the earth going into the amp falls out all the time and black tape doesnt seem to do the job very well. Anyone got any suggestions?
Edited by Polo-Bluebird
  • Views 739
black tape?
most amps have some kind of hold down screw to secure either the bare wire or a crimped connector
i think i know what you mean, as in the wire is connected to the terminal but it slips out, i got 2/0 what I've done is soldered the wire to the terminal and crimped it as hard as i could then use heat shrink n it should b fine
