Tinting My Rear Lights Red
Hi all,
I want to tint my rear lights all red at the weekend and wondering how it is done and what spray to use?
I read somewhere that you need to use a green bulb to make the indicator flash orange?
Thanks for your help in advance
Matt
  • Replies 24
  • Views 4.5k
you can buy light tinting spray from Halfords,ebay and the like and its a case of clean them off and spray a couple of coats on (lightly) to acheive the look you after and yes a green bulb should make the indicator appear orange through them :)
Ok mate i did mine last week wz easy
jus tke out lights and spray with light tint spray from ebay.
came out great jus remember to go slowling doin light coats at a time and drying with hair drying after every coat
looks proffessional. And can come off with stripper if goes wrong.
Another way to do it is with window tint film but dnt know much about that.
Great thanks for the replys, looks like you got a good finish there, gonna try it this weekend with the red tinting spray and well post a pic up when I 've done!
:thumbsup:
do you primer the lights first or just go stright to tiniting them? lloks good and what about clear laquer. I'm doing mine next weekend :D
sent you pm polocsv how to do it correctly
DO NOT primer as it will block the lights,
# remove lights from car 3, 9mm nuts inside car and remove bulb holders
# wash lights inside and out with hot soapy water
# dry and wipe off lights with white spirit or panel wipe
# spray light coats over the light until the desired colour is achieved
# then they can be laquered but test it first on something else in case it reacts
# leave to dry for a few hours, refit and enjoy
anyone actually sprayed there lights red then? can i see some pictures.
thought about tinting mine red... decided to just buy some mk5 rears.
i tinted mine, I'm now setting out to remove the tint, but if you do this remember to laquer the lights after, i sprayed 5 coats of laquer on mine, the more coats you put on the shinier they come out
I was thinking about mk5 rears but everyones got them now and I like the look of the 6n rear lights.
And I dont have a spare £50 lying around either...
Edited by polocsv
http://www.lamin-x.co.uk/
Its a light tint film, just measure up how much you need, and order it away!
Its great stuff, just peels off when your done too!!
Weras spray, I'm finding it difficult to FULLY remove all the red...as my Jetta has it on all the lights from previous owner! And I mean, all the lights, side repeators..the lot! Lol Looked stupid IMO!
So, Did you spray the outside or the inside?
I might do this the weekend too...
I thought it would be easier to paint them inside out? That way you'll have the outer plastic shine / protection?
So do mk5's fit a mk4?
Ok so if i sprayed them red, and get a green indicator bulb.
What happeneds to the reverse light? I would have to tape it up, right?
Oh and where the foof can i get green dinicator bulbs?( not many on ebay)
if your going to do it make sure you really think about it, dont spray the inside i dont think it will work the same lol
:lol:
I'm doing it this sat with laquer to make it shiny - I'll post a pic when I've done.
what u going to do with the reverse light?
Think I'm gonna leave it but once I've done the indicators I'll see.
yeah show me a pic of the indicator please, are you not respraying the lights that are red already or you just going to level it all out with lacqucr?
If you wanna tint your rear lights to become red, i suggest tint film. Sprays can often distort the light output when driving in dark atmospheres. I bought my tint from ebay, type in 'flyseyes'. The tint he gives you has different colours, just ask him for some and it doesn't distort the light output but yet it does give that tint look and style. His name is Jason and he is a reliable guy to do the job. Spray is a pretty time consuming job, just stick some tint film on and there you go....job done mate. I believe his company is called FLYSEYES, look it up on ebay.
V-MaN
thx, but do mk5 lights fit mk4? would be easier to use them
Cheers for that mate I'm gonna look into that tint film now - didnt manage to tint my lights went to my local motor factors and halfords and none of them stocked it :-S
MK5 lights do fit the MK4 but you have to cut them to get them to fit and also change the wires inside to match - I think putting either tint spray or film on the indicators would be a lot less hassle tbh
Oh and I prefer the MK4 lights.
P.s I'm leaving the reverse light white.
Edited by polocsv
i done two sets of red mk4 at the weekend and am sellng one pair :D and i left the reverse light white 8-)
Can I see a pic please?
