Passenger Door Lock Stop Working
Hi i hav a mk4 polo
my passenger side door lock is now not wrking ( not locking of unlocking jus twisting)
It use to be a lil stiff b4 but nw totally not wrking
any suggestions?
  • Views 650
Popular Days
Could be that the bar from the rear of the handle has broken/dissconected inside
best bet is to take a torx bit into the dorr sut and you will see a screw for the handle, undo this and slide the handle forwards then pull the lock end out first and it should have a protruding part on the back which goes into a flat hole inside the dorr.
if its not there or broken then replacements are available through motor factors or it may have simply come apart
