Anyone Know Were I Can Get A "fudge Wheel"?
cheers
  • Replies 22
  • Views 2.8k
do you mean a "donut"?
to get the sticky stuff off after taking od strips 'n' stuff??I've been told itd a fudge wheel??
petrol on a rag. worked a treat.
ebay. thats were i got mine.
its called a toffee wheel, and you can find them on ebay..
or a fudge wheel...........................
ebay doesnt list any items for fudge wheel :p
White spirit got all mine off
Can of sticky stuff remover and a rag. WHy waste money buying extra stuff when all you need is some petrol/wd40/sticky stuff remover?
ebay. when i get home ill post the name of the on i got from ebay
please ignore what anyone says about white spirit, any fluid based stuff
fudge wheels take the glue off, and what wd40 and white spirit doesnt take off is the actually plastic foam stuff
it will take you forever with wd40, and with a fudge wheel you can do both sides in little under 15minutes
the people saying use fluids i can 99% say they haven't ever used a fudge wheel!
once you go fudge theres no going back!
Quick question then Dan - is it literally just a case of attaching this to a drill and then whizzing away at the sticky stuff? Or is it very easy for a numpty like me to fuck it up?
no its dead easy, my first thought was "am i gunna naff the paintwork" but it doesnt, you just stick on drill, a bit of lube for sake of it, and just whizz away, slow to start if need be, but it just picks off and the toffee fudge just comes off with the glue and foam
it really is good stuff, if you press on alot then I'm sure you could take paint off, best bet is to try it on a hidden bit of paitnwork to see if you can do it lol
^^^ i think youd probably have to try to take pain off with one of those tbf
cheers guys!
:lol:
i did mine with a toffie wheel and i took off the dodge paint some dirty bodger put on
good tool never even bothered with fluid stuff its not worth it for the price of a toffie wheel
good luck
iirc frost.co.uk also sell them?
what did you use as lube?
Edited by tjr1711
I'm taking my side strips off... used petrol and a rag when i took the badges off but I'm temped to try a fudge wheel... if it really is that good!
Right before anyone starts using a toffee wheel, be careful you do not burn through the paint because then you have to have paintwork done, to prevent burning through the paint jus dont let the toffee wheel get too hot, aswell as the paint/panel.
