New Door 6n
gonna order a second hand front door skin from vws tommorow, just wondering if the only one they ave is electric window door can i convert it to normal winder as that is what my 6n is, and how esay is it to change the lock barral on their mine is not central locking any help really appriciated
  • Views 980
The dorr itself will be the same for either car, You will need to swap everything over from your existing door into the new one, the lock barrel comes out of the handle but the handles will swap straight over
bear in mind if you are buying a SKIN then it may be just that, a repair panel for the outer of the door, check what it is first
kwl mate sorted, all i want is te skin because some little runt broke into mine and bent the top back which has now got a bloody crease in it, so if its the skin, i can just transfer the trim and everthing onto it and away we go
iirc a SKIN is just the metal outer that covers the main body of the door...
thats what i meant to say :) i,e just the outer panel minus the bracing and actual door structure
Also you cant buy a second hand door skin. You need to buy the whole door. which door do you need? , i have both doors in flash red.
