Restoring Paintwork
I've got a red 6n 16v and the paint is just starting to fade on some panels.
does anyone no the best way to get the paintwork looking nice without a respray?
Polish.
You want a cutting polish. Meguiars do paint a restorer, but if that isn't enough then Farrecla G10 might work or it might be too fine. If ithat doesn't quite work, then try Farrecla G3 which is a coarser cutting polish, then the G10 after. Be careful on edges and don't go mad as it is quite a coarse cutting polish, but I've done whole cars before with no problems. Try one panel at a time, then you can compare with what you haven't done and if you're happy with the results, you can go on to do the rest of the car. After that a decent polish, then some sealant, then some decent wax to protect it.
Is that the same as cutting compound? That stuff is smazing.
T-Cut
i used T-cut, then i waxed it
took around 3 hours, it makes it look nearly new lol!
that was on my black polo, my dad said back in the day he done it on hes red xr3i and it looked like wet paint!
Edited by mikepolo
i think i need to get a few of these item for my red motor paint is as flat as a pancake and has gone white in areas?
LOOL
