Black Vw Badge
i was just wondering where every one is getting these from, or if everyone is spraying them themselves
I've got a 6n2 gti and was looking for front and rear,
  • Views 891
take badge off clean and sand with 240, bit of primer then your choice of paint and laquer if needed :)
cool, how do i get the badges off, are they stuck on, if so how do i stick them back on
front badge will unclip from grill, usually about 4 clips when you look behind there and the rear should be stuck on so will need to be restuck afterwards with a strong doube sided tape
also if its a gti grill then there will be a torx screw in the center of the V on the badge that needs removing to unclip the badge.
