Flooded Floor
Hey guys and gals...there's a pool of water behind my drivers seat on the floor in my 6n 5dr!!
Does anyone know why this may have happened and if this is a regular problem with 6n 5dr's???
Thanks all
  • Replies 14
  • Views 1.7k
Thanks all
i had same problem, door seals was my problem and splash guard under wing was missing so that wasnt helping.
sunroof drains blocked, scuttle panel drains blocked? check those 2 and report back
to dry it out go for a drive with the windows down and the heating on full blast aimed at the floor or leave a tray of salt in there to soak some of the moisture up
sound like a seat LoL
its probably the door seal
thanks lads i'll check out the seals and everything and replace em if needs be
Had the same in my 3 door, although the seal looks fine. What could be up with the door seal, as it does look like some water might have seeped from the bottom of the door seal area towards the floor.
i had the same problem with my leon cupra the door seals looked fine but when you open the door after its been raining you could see where the water had gone over the bottom of the door seal
I've got a proper bad damp problem in my boot! its soaking! 6ns must have a serious fault with leaks :? its a pain in the arse
My 6n has the same problem in a certain spot, its not alot though...Can't really suggest anything apart from try and find the route of the problem
i had this prob it was because my front door had droped and water was runningng to the back
I've got this problem in my mrs' 6n, rear footwell behind the passenger is absolutely drenched, I've checked the scuttle holes, they wern't blocked but had some leaves and mud collected in the channels leading to them, cleaned them out but still leaking.
Also looked in the sunroof holes at the front which were fine, how do you get to the rear ones?
I think i've found the leak, it would appear that my pollen filter box is completely loose from both the fitting bolts rusting away.
The water is literally dripping from underneith the dash on the passenger side down the edge of the blower fanand on to the wheel arch, down in to the footwell.
What I need to do now is somehow block the pollen filter box until I can get it sorted at the bodyshop or something.
I was thinking blocking up the entire hole for the time being which would obviously mean I can't use the blower but the car is off the road for the minute due to no insurance.
Does the place for the leak sound about right or am i missing some crucial piece of info?
check your water pipe to the rear window mine leaks into the rear passenger footwell when i try to squirt the back window so i dont use that anymore lol
polo's hey u gota love em
My 6n2 5dr front door leaks like a sive. the footwell was under 2 inches of water. i stripped the whole interior out, down to the metal shell and searched for a leak... it was coming from the water deflector at the bottom of my window... it was leaking water in and then running inside my door card down to the speaker and out onto the top of the door gasket and finally running under the carpet!!!
i tried to place a piece of polethene over the inside of the door so it would deflect any water out to the bottom of the door where it's meant to go... this didn't work to my annoyence so i'm gonna change all the gaskets and deflectors... NIGHTMARE :x
Edited by steves6n2gti
I patched up my pollen box hole but the bastard is STILL leaking.
I'm gonna go and do a watering can test in a bit but this is seriously getting on my rag now, steves... what deflector is that?
