Whats Different On A Gt ?
I have been offered a J reg Polo coupe GT with a knackered body and I have a Y reg breadvan at the minute.
What good bits can I swap over?
What is different on a coupe GT ?
New to Polos so help would be appreciated :-)
  • Replies 10
  • Views 987
I'm pretty sure there is a write up on differences on here just use the search button top right bud
Brakes, wiring loom, Fuel lines, Engine/gearbox, Clocks, interior, steering wheel, ermm I may of forgot something.
probably 20/30bhp!
I was definitely thinking engine and 5 speed box, just wasnt sure about differences in the brakes / suspension etc.
Are all gt's the same engine ? the 1.3 multi point injection? are any single point?
All are 1.3 MPI
all GT's are 1.3 8v MPi engine code 3f. not be confused with a 2f which is a mark 2 facelift or what we like to call a mark 3... GT into a mark 2??? dooooo it!!! dont forget the steering dampner aswell, although i found polos handle more fun without it tbh!! but depends on your style of driving
Brakes aren't different between GTs and any other Mark3 Polo (except the G40). Its a common misconception.
GTs still use the solid VW I 239 set-up as late Mark2 Polos (around '86 and later), and Fox, CL, etc Mark3 Polos.
However, as your Mark2 is a Y reg, you'll no doubt be running the Girling 'postage stamp' type brakes upfront. Some find them adequate (for up to 55bhp), some find them attrocious. I wouldn't want to try stopping a standard Mark2, never mind a GT converted one on the Girling brakes!
Dont forget the rear axle,which has an anti-roll bar welded into it - not a five minute job,but it'll help keep traction in cornering.
Its quite frustrating wading slow and wide out of corners under power with the back squatting and the inside front wheel spinning. You may not be a rally driver,but 75bhp can pull 730kgs about quite well and its worth havin.
