Removing Window Winders On Mk3 Golf
as above... i need to remove the door card from my mk3 golf to get the the back of the lock, but i dont know how to get the window winder off... can anyone help??
  • Views 1.8k
Is it not like alot of cars where you prize off the cover with a screw driver and undo the screw?
dont think so, I've not seen a cover. looks like its all one piece
there is a plastic ring behind the winder handle, same colour as the handle and about 5mm thick, you have to push it either in the direction the winder is facing, or the opposite direction (cant remember which :lol:) once you've popped that to the side the handle will just slide off
took me hours to work it out :lol:
hope that helps
