Must Do Mods For Coupe S
Mate of mine has just picked up a 50k Coupe S for FREE! Ok, so the head gasket has gone but still.
What are the must do mods for the Coupe S?
I'm thinking things like chucking the Pierberg in favour of a Weber, maybe some better brakes?
Cheers chaps. :thumbsup:
  • Replies 12
  • Views 995
Depends what he wants from the car?
Does he want a modified car? Or are you talking mod's that will better the car but keep it standard on the open eye?
If hes modifiying, ide say a good place to start would be to lower it, and get a set of nice wheels! And if theres any bodywork needs doing, show that some love! Thats should be a great start to modifying it!
As far as engine parts that could be a good idea replacing, I dont know that much about polo, having only ever owend one mk4! But someone on here will be able to highlight the problematic parts of em I'm sure! :thumbsup:
Also with my experience with Pierburgs (on golfs and jetta's...) when there good, there good, when there bad, there bloody aweful!!!!
I had a webber on my first golf, and it took a bit of doing getting it all running correct, as I didnt know, but the flange to the inlet had ahairline split in it...once I found that out and replaced it, it was the best mod I did to the car!
Edited by mk2danny
Webber DMTL Carbs give a slight increase in power and make a nice noise too ..
Taking the mid box out gives a nice exhaust note .
80mm Hot tuning spring and shock kit will make it alot stiffer lower and make the handling alot more responsive . (Phil Jackson on here) Around £160 for full kit
Get some poweflex poly bushes too they make handling more responsive
Other than that your talking alot of work and alot of money with such things as subframes , bike carbs ect .
Hopefully this helps ..
Steven
Edited by Stealth
lower a little... maybe 40mm?
I wanted to do that to my coupe s when i had it. and a chequered roof. otherwise totally standard.
Not really interested in the visual mods, and lowering/wheels is a given really. What i'm really referring to is anything that is almost essential,. that everyone would agree has to be done - like transplanting parts from a GT etc.
Bike carbs, cams and such would be overboard. But simple, effective mods are the call of the day here.
Obviously the car will be getting a full service anyway as the heads coming off for the gasket.
while the head is off get it port n polished will be quite cheap while head is out :thumbsup:
my list of essential mods for a coupe s.
remove the carb and clean it out, check the condition of gaskets
get the co and air to fuel mixture set up on the pooberg
mini service (filters - oil/air, coolant flush, fresh oil, spark leads, plugs, rotor arm)
treat any rust with kurust or the like
Suspension kit, 70/60 is perfect on 13 or 14s, 60/40 is better for 15s. Renew any worn suspension components at the same time (arb & tca bushes, lower tcas if ball joints are shot, top mounts and front and rear bearings)
fit vw2 calipers with the vw1 carriers (for more clearance), g40 or mk1 golf vented discs and fresh pads, fresh fluid and a brake bleed
obviously as you have to do the headgasket, youd want a full hg kit which contains all the gaskets and valve stem seals etc. get the head skimmed and valves three way diamond cut (cheap as they will have to be removed anyway) fit new head bolts, new water pump and cambelt, might as well fit a new alternator belt while your there
little jobs, like making sure all the bulbs and electrics work and ensuring a good seal on the doors and bonnet.
enjoy and happy motoring
i would also consider fitting a steering damper from a gt or g40, just dont forget the bracket from the steering rack as youll need it!
Edited by grungeisdead
Thats the ticket, ta grunge!
MK2 headlamps are pretty pants,I've fitted the 50 percent brighter xenon items,adjusted the lamp height properly for a sociable dip yet a good main,and i still cant see where I'm going at night - but its better.
There's 80 percent super dooper brilliance xenon nuclear lamps available now,though completely blinding oncoming traffic can have its setbacks.
headlight loom with relays is a nice upgrade
replace the worn out suspension bits n bobs and maybe some poly bushes up front
If your wanting it to last and its one that has the plastic sill trims, drill out the rivits, take them off and have a good check underneath for rust. could do the arches as well, always good to give it a good underseal as well and check the petrol tank is ok, and paint it up before it rusts especially around the filler neck. A lot of crud collects underneath there over the years, in an ideal world you would take it out but you should be able to poke about behind it with a slim screwdriver and get most of the muck out, then get an aerosol underseal and have a good spray in there.
always a good idea to see that you have a nice sound car to start off with, and that rust under the sill trims is a complete git once it starts eating away :-(
Lower suspension brace... transforms handling on any MK1, 2, 3
Suspension 40mm
Polo G40 (Mk1 Golf gti) vented front disc and brakes especially if it is an early one.
check the rear exhaust mount is secure as you mate does not want to look a prat when the exhuast scrapes and fall off as the rear mounts are not that great.
Weber dtmr as mentioned above ( but cut out the blanking on the mounting bracket so both ports work!
185 tyres
I've yet to see the little beast so not sure of the current condition. I know the HG has gone before now, so there could be an underlying issure there...maybe it wasnt skimmed after the last time praps?
At 50k miles hopefully it should be pretty decent though. Will get those arches and fuel tank checked, been so long since i had my GT's and Coupe S that i've forgotten all about these issues!
