Brake Upgrade For Sale
hi i have a set of callipers and brand new still in the box drilled and grooved discs for a corrado g60 280mm.i was going to fit to my polo 6n but i just bought a set of hi spec brakes so these are up for sale.they are a straight fit.
  • Replies 15
  • Views 469
how much mate pm me a price ? and wer u based ?
i would want around 200 mate they are down at a garage in bridgwaer somerset.
Are thease carriers, and disks ? and will fit a mk5 gti ?
cheers
cheers
hi yes its a pair of drilled an grooved 280mm discs and g60 callipers and pads am not to sure if they will fit a mk5 but there a straight fit on to a polo 6n.
thanks
Surely without carriers this is overpriced ALOT..
so thease don't have the carriers ? bit that holds the calliper in place......
as i would only need disks an carriers, and use my existing callipers!
I'm not to sure what carriers are but everything is there to fit them straight on to a polo 6n i had them fitted then removed them for my hi spec brakes.
Carriers are the two objects to the left and the calipers are the two objects at the front of the pic...
Do you have them?
Do you have them?
thanks for the pic yes i have them there forsale
cheers
100% ? can you get a pic up mate ??
was your polo a 16v what you took the brakes off cos I've heard that the carries on 8v are solid to the swivel hub not shure tho but these defo will fit 6n 16v or 6n2 gti cos thay've got seperate carries
Rye
Rye
yes mine was a 16v an they def fit a 6n 16v.
cheers tom
hello mate,,,whats the best price you could do on these,,,i dont think they are worth £200 mate..
there brand new drilled an grooved discs still in the box cost 130 i would take 160 then if they get picked up
pm sent
