Dhla 40 Jets For A 1300
i emailed a bloke asking about what jets i should use for my 40's which are soon to be going on my mk2 golf 1300, he reccomended as a starting point;
chokes 30
mains 115
airs 200
em.tube f11
idles 45f8
pump 35
n/valve 150
do you think these sound more or less right? I'm going to get it RR'd but i dont want them to tell me I've done it all wrong and have to buy another set of jets etc.
my golf is fairly standard bar a full powerflow system and i will be adding a GT cam.
thanks in advance, konrad.
Edited by konradmk2
  • Replies 37
  • Views 12.4k
It will run fine on them, but maybe a little rich i'd have thought.
I used 29mm chokes on a 1400 and got 95bhp, so 30's are probably oversized. you could use 28's or 26's and then jet it from there. - 28's probably best.
A general rule that i've read is to get the choke size and multiply by 4 for the main jet size, so 28mm chokes with 110's would run fine. Then air corrector size of 200 sounds ok. 33pumps would be fine. 7772.5 tubes would be fine and needle valve 150's fine. Then the RR tune for the best power.
Edited by twin40racer
what carbs are they?? if they have a letter after DHLA40 then you will find that you cannot fit 7850.n idle holders and are restricted to 7772.8,.10,.11 emulsion tubes. the idles will have to be increased to 58s or 60s.
if thats the case then you want to get a set of 7772.8 emulsions as they're the earliest starters and hold the strongest mix.
keep the airs and the mains
you've been quoted weber numbers
45 idle 7850.1 idle holders
reduce the size of the air corrector to about 170
they have a 'H' after the dhla40.
thanks.
  • 7 years later...
Found this 1971 spec for twin cam 1290cc Alfa Romeo Giulia Super 1.3 which I think is 100+ BHP 9:1 compression ratio
1971
http://www.carfolio.com/specifications/models/car/?car=100034
1972
http://www.carfolio.com/specifications/models/car/?car=37125
Chokes 28mm
Main 110
Emulsion .5
Air corrector 200
Idle 48/7850.1
Pump 33   (4cc per barrel per 20 strokes)
Aux venturi .1
Starter 70/7840.1
Edited by dvderlm
In contrast the single cam 1298cc 87bhp Vauxhall Nova Sport 1.3 in road trim used Weber DCOE (143&144 matched pair)  - compression ratio 9.2:1.
Choke 28 mm
Main jet 100
Emulsion tube F47
Air corrector 160
Pump 40
Idle jet 59f21 (4x1.10 mm bleed)
Edited by dvderlm
Lancia Fulvia 1.3 coupe (sport and zagato)
http://www.viva-lancia.com/fulvia/qanda/carbs/dellorto.php
Used similar smaller than DHLA40 twin carbs Called DHLB35. some parts interchangeable, but sizes interesting as this was an upgrade on Solex C32 PHH twins rated 87bhp.
Chokes 31mm
Main 112
Emulsion 7772.4
Air corrector 200
Idle 45/ and 1 x  1.2mm air
Pump 45   (2.5 +-0.5cc  per barrel per 20 strokes)
Aux venturi 8178.1
Starter 70/7482.2
Edited by dvderlm
7772.04 dellorto was almost a googlewhack
Renault Alpine A110 1300S (R8 Gordini type 804)
(120 BHP  compression ratio 12:1)
Weber 40DCOE (29&30)
Chokes 33mm
Main 130
Emulsion F15
Air corrector 200
Idle 50f8
Pump 35
Edited by dvderlm
Lancia Fulvia 1.3 HFR Variante 1014 (122 BHP @ 7200rpm?, 9:1 compression ratio)
(according to Solex S.p.A. Technical Bulletin No. 71/October 1967, supplied by the Lancia Competition Department)
http://var1016.blogspot.co.uk/2006/12/fulvia-thoughts-6.html claims 132bhp, but most sources say that's 1.6HF power)
Solex C. 40 DDHF
Choke 34
Main Jet 145
Air Corr Jet 155
Idle jet 50
Edited by dvderlm
If you speak French there's a mec called Jean-Christophe Nieutin who has done tuning on Lotus7 1600 and Alpine A110-1300. He likes Webers, so much so that he's created an Excel spreadsheet for calculating optimal jet sizing
(and loads of other info...).
http://a110a.free.fr/SPIP172/IMG/xls/Carburateurs_Weber_NIEUTIN.xls
It works with LibreOffice.
 I edited for my GK which I think prefers lean as 11:1 compression.
I adjusted the fuel coefficient (cell C1) down to 94%
It's ONLY 1263cc (cell B6) according to the Farhzeugbrief, I think because the piston bowl is smaller.
I set the bore to 75.0mm (D6)and it worked out the stroke as 71.5mm.
I chose Souplesse=flexibility over Performance/"puissance" (cell B8).
I guessed the idle jet has 4x1.10mm air holes (B2 and B2) and it reckons a single 2.2mm air hole is as good.
I aimed for max power at 5500rpm.
and it suggests
idle 40F8
chokes 26mm
main 100
air corrector 160
pump jet 30 to 35
emulsion F11 rich or one of F16, F15 and F9 to weaker.
If you have other choke sizes either side of 26, there are suggestions for these in row 8 and 9.
It chose the 100 from a list of available sizes for Weber rounding up from size 98 (cell B11)
Dellorto do a 98 jet!
It also works out the engine is Super Carré, which I think means over square so can manage 8811 rpm max, before piston speed exceeds 21 metre/second !
Edited by dvderlm
Citroen Visa Rally 1285cc
http://www.citroracing-historique.org/Documents/WeberSettingsVisa.pdf
Weber 40DCOE 185
35 choke
140 mains
165 airs
F47 emulsions
59f21idles
35 pumps
4.5 aux venturi
Float lowered 1mm to 8.5mm from std 7.5mm.
ignition
Fixed advance 32° at 5000 rpm.
Others have 4.6° at 1000rpm and 30° at 5000rpm
Sideways Forum
http://sideways-technologies.co.uk/forums/index.php/topic/5892-what-carburettor-race-1300-engine/page-3#entry78256
contributor DaveNotSoSideways (who I suspect is "Barry Scott crazy spitfire" blogger David Powell http://crazyspitfire.blogspot.co.uk/2006/06/days-like-these-make-it-all-worth.html)
suggests turning down a .7 emulsion tube in a lathe as .5 tube is too thin.
34mm choke
.1 venturi
33-40 pump
125-135 main
lathed custom .7 tube
150-160 corrector
idle 55 in 7850.1 holder.
Or to use a .6 emulsion tube:
34mm choke,
.1 venturi
35-40 pump
128-135 main
6 tube
120-140 corrector
But I also found why he likes large idle - his engine is run very cool
http://crazyspitfire.blogspot.co.uk/2005/01/weber-dcoe-dcom-jetting.html
http://home.wtnet.de/~shensiek/weber2.htm
30mm chokes 120/200 - standard, light tuned
32mm chokes 130/200 - sport cam up to 296 cam deg
34mm chokes 145/180 - big valves sport cam up to 316 deg
Talbot Samba Rally (90hp @6700rpm -not the 135bhp group-b )
 1219cc
33 chokes
130 main +-5
195 air +-5
F47 emulsion
55f21 idle +-10
with 110f2 air-bleeds
40 pump jet +-10
Edited by dvderlm
Alfa GTA 1300 "Elaborazine Facetti"  (1972 race car)
95bhp @ 6000rpm 10.5:1
(or 178hp @ 9,300rpm with 11:1cr)
1290cc 78x67.5 bore x stroke
DHLA45!
40 choke
.1 venturi
165 main
.6 emulsion
170 air
50 idle
.1 idle holder
33 pump
volume 7.5cc +- 0.5/20 strokes (per barrel)
Edited by dvderlm
Simca 1000 Rallye 3 (1294cc)
103hp 13:1 CR
Weber DCOE 40 120/121
32 choke
6 aux
160 main
F41 emulsion
190 air
40f8 idle
40 pump
float lowered 7.75 and 8.25mm (front and rear carbs?)
Edited by dvderlm
  • 4 months later...
On ‎04‎/‎11‎/‎2016 at 22:28, dvderlm said:
DHLB35 ... as this was an upgrade on Solex C32 PHH twins rated 87bhp.
which were jetted:
26 choke
107.5 main
180 air corrector
47.5 idle
40 pump
7cc per cylinder from per 20 strokes?solexc32phh.PNG.1f622df9465b6c86599e95465d4836b4.PNG
Edited by dvderlm
  • 4 months later...
http://la205rallye.free.fr/doc/noticecitroensportax.pdf
Citroen AX Sport 1.3
1294cc 94hp
9.2:1 CR
Weber DCOM 40
32 choke
115 +-5 maim
140 +-20 air corrector
F68 emulsion (very holey, hence small air corrector)
58f21 idle (+-5)
35 pump +-5
(40/f9/130 starter circuit? or alternative idle stsck?)
float level 14mm (plastic) 7mm (brass)
or
Solex ADDHE 40
32 choke
130 main
210 +-20 air corrector
A05 emulsion
55 idle +-5
50 pump jet +-5
1 to 2mm pump travel
( 140 starter fixed)
float level 43mm
I guess different temperature, altitudes, rally track surface are the reason for the +or-- values. But either carb types are suitable for exact same engine..
Edited by dvderlm
You do realise the OP hasn't been on since 2012 right?
Yes.
But where else would I create the best collection of twin carb 1300 data on the web?
  • 4 months later...
Skoda S120 (Rallye ?)
1300cc 111hp @7250 rpm
10.8:1 CR
DCOE 2
34 choke
145 main
180 air corrector
45 idle
80 pump? enrichment power jet??
with 320 degree duration cam.
This one is using DCOE45s and a Felicia engine
Edited by dvderlm
