Dhla 40 Jets For A 1300
Slalom Polo by VGS motorsport Cologne
Engine overbore 1298.2cc 128 HP @? rpm
https://www.facebook.com/pg/slalompolo/notes/
Weber DCOE 40  136/137
Chokes 32
Aux venturi  6
float level 7mm
main
140
emulsion
F47
air corrector
160
idle 55f17
30 pump jet
Wow, he's dry-sumped it. Not on the Webers anymore
Edited by dvderlm
  • Replies 37
  • Views 12.4k
Fiat 128p flowed and tuned
1290cc 10.2:1 CR
http://www.guy-croft.com/viewtopic.php?t=1444
(faster than 120hp Alfa GTV which I reckon has twin Dellortos as standard)
DHLA 40 (no suffix)
Choke 32mm
idle holder 2 (was 9) with mixture screws 7 turns out!
idle jet 40
pump 40
emulsion tube .5
mains 120
air corrector 190
  • 5 months later...
Sprite and Midget engine 1500cc
Twin Weber 40 DCOE
Standard
Aux 3.5
Choke 28
Main 115
Air 170
Emulsion F16
Pump 35
Idle 45F9
Fast Road
As above but
Choke 31
Main 125
Race
as above but
Choke 33
Main 130
Pump 40
Idle 50F9
https://books.google.co.uk/books?id=V3STrysMNjQC&pg=PA39&lpg=PA39&dq=dhla+sizing+venturi&source=bl&ots=p8IL_fkWka&sig=ACfU3U2wYJdUjzmkntfHmhMw32_5F7WWRQ&hl=en&sa=X&ved=2ahUKEwjN07bKhdHlAhUKEVAKHWLtDd4Q6AEwEnoECAkQAQ#v=onepage&q=dhla sizing venturi&f=false
  • 1 year later...
AlfaRomeo Giulia Super 1290cc
9:1 CR. 89bhp @6000 RPM
140Nm torque  at 3200rpm.
Solex 40 ADDHE 11.
with holey emulsion tube (3x 0.8 5x1.0 holes)
Choke 28
Main 117.5
Air 155
Pilot 57.5
Pump 45
Pump vol 20 squirts  7 +or- 0.5 cc
Needle valve 1.6
Fuel level 18.5 +or- 0.5 mm
Starter jet 140
Edited by dvderlm
O.S.C.A MT4 1342cc twincam
(in 1450cc twin spark form this gave Stirling Moss 12 hours of Sebring win in 1954)
100bhp @6300 rpm
9.0:1 CR
Weber 38 DCO3
Choke 31
Main 120
Emulsion F1
Air 150
Idle 55 1.2bleed
Pump 70
Needle valve 2.25
Osca MT4 1350 Morelli Spider, 1952 [Auta5P ID:11206 EN]
Two thirds of a 1968 Porsche 911T Turbo 6 cylinder 1991cc.
is 1.327litres.
67hp? @ 5800rpm (all 6 cylinders gives 110hp and 177Nm torque at 4200rpm)
Compression ratio 8.6:1
Weber 40IDTP3C
Choke 27
Main 110
Emulsion F3
Air 185
Idle 50
Idle air 110  (in carb body; the F10 idle holder has no hole)
Pump 50
Enrichment 70
Float height 20.75
http://forums.pelicanparts.com/porsche-911-technical-forum/431669-weber-carbs-diff-between-ida-idt-idtp.html#post4196754
Edited by dvderlm
Hello, I have toyota corolla 2E engine and I install Solex 40 ADDHE carbs, can someone help me with jetting, what jets should I use, The engine is 1,3 12V 55kw
I'm not familiar with that engine, but know the Yaris 2NZ-FE and and 2ZZ-GE licensed by Lotus.
I don't know much about Solex twin carbs either.
A lot will depend on the choke/venturi size in the carbs and the cam duration...
Which 2e version?
https://www.engine-specs.net/toyota/2e.html
Also see this thread...
Lancia 1.2 used 42.5 idle.
(Engine will also need more ignition advance at lower revs on twin 40s than a single carb but about the same maximum advance.)
Edited by dvderlm
Which 2e version?
i have problem with carbs, I had a back fire in carbs was 45idle jet and 145 correcton jet, than I change them for 55-155 and now car have less backfire I have sometimes when Im driving around on low rpm, and when I give fuill throttle my car bog down want to die, but when I go slowly on gas pedal than car run normaly
Innocenti Cooper 1275cc  9.75:1 CR
71bhp @ 5800rpm
107Nm at 3200rpm
Innocenti Cooper 1300 [pics] | Retro Rides (retro-rides.org)
https://en.wikipedia.org/wiki/Innocenti_Mini#/media/File:Innocenti_90_-_120_-_Mini_derivative_A-series_engine.jpg
Twin Dellorto FZD 32.28
Choke 28
Aux 6641.1
Idle 48
Idle air bleed 80
Main 135
Emulsion 6747.3
Air corrector 190
Pump 50 (8cc +- 0.5 in 20 strokes)
Float height 5 or 6mm?
Dellorto_calibration_table.pdf (vintagegarage.ru)
Edited by dvderlm
Vauxhall Nova Sport Group A rally car 1300cc
Weber 40DCOE
Ignition at 32deg @ 4000rpm
Choke 28
Idle 52f26
Main  125
Emulsion F16
Air 170
Pump 40
Just wonder how they rejetted for Brands Hatch
https://www.motorsportmagazine.com/archive/article/november-1986/40/musings-reasoned-racing
Ivan commented casually, “Just rev it to what it will reach, you’ll never break it.  The needle will disappear beyond 7000, but you’ll only need fourth on the longest straights…”
Edited by dvderlm
  • 1 year later...
  • 2 years later...
Surprised I never added this one.
Sorg Polo GK twin carb as in the Gutachten (hotly traded in Germany as it is required for inspection on modded cars)
Weber 40 DCOE 136/137
Choke 31mm
Idle 55f21
Main 120
Emulsion f34
Air corrector 185
I assume this for the Sorg SM1008 plenum.
https://www.polotreff.de/forum/t/63700
https://www.motor-talk.de/bilder/suche-ein-gutachten-fuer-40er-webervergaser-fuer-meinen-polo-86c-1-3l-g75386024/sorg-3-i208605153.html
Edited by dvderlm
