Question On Primer
Total novie, so to those in the know, i can see this'll be a dumb question. Have asked elsewhere, but either they don't know the answer, or i'm being blanked :D
Had to do a job recently requiring black paint. Picking up all the goods from Halfords & using their chart, it says i need grey primer.
Looking to do a job later on which will be orange paint ... this required white primer IIRC.
Red paint requiring red primer IIRC
I'm just wondering, why the different colour primers for the different colour paints?
Also, as grey is recommended for black paint for example ........ what'd happen if you used white primer or red primer instead of the recommended grey?
Just to satisfy curiosity really. Cheers.
  • Views 943
I'm not too sure but I always thought that that primer reflects on the shade of the colour that will be sprayed on top.
I think the gray primer is because when you spray black, it must be perfect....maby the gray primer is to show up imperfections?
And way i'm shit at this stuff, its just what I always thought.
lol, not to worry. At least you've had a crack. You're the only one on 3 car forums that's even attempted to answer :)
LOL Can somone tell me if I'm right? I don't want to know if i'm wrong.
generally when you spray cars on a higher level you use a primer similar to the topcoat colour to keep it accurate to the base colour, as you say reds under reds and whites under silvers and the like
Another one i haven't really got any joy with & maybe i'm googling in the wrong places, but...
I know what primer does. It's pretty obvious what the paint does.
Lacquer....
I just automatically bought some for the job i was doing, because everyone else with the guides had but when i ask what lacquer actually does, i wasn't really getting any info.
I was under the impression that it's some sort of protective coating, that in the process also adds a shine to it.
I've so far only had 1 reply, which was a bit vague, which sort of implied that ALL lacquer does is add shine, nothing else.
So, what does it do exactly?
EDIT...
While i'm at it, i may as well also ask...
Plastics - such as grilles and engine covers
Once you've done a paint job on these - primer, paint, lacquer, is it ok when you're done to put these in an airing cupboard where a radiator is?
Reason i ask is 2 fold i guess....
After the lacquering had finished, i left my grille 3 days, but the layer still smudged when touched hard enough. So after THREE DAYS it still hadn't fully dried.
Also, if you leave wet boots next to a fire to dry out, it can crack them, instead of just drying 'naturally' - which is the main reason i ask if the plastic can be put quite close to a radiator.
Edited by Kev_83
