Doors Wont Unlock
Have a problem with my 6n. this morning went to get in my car and everything worked as normal. got home parked up. went out 20 seconds later, put the key in the door and went to turn it to unlock the doors....nothing happened. so tryed again...same....
went round to the passenger side and turned the key....nothing happened. only way to get in the car is via the boot and manually unlocking the doors from there. what is up with it :S
you can afterwards lock the doors via the passenger side but then it doesnt lock the petrol cap.
any ideas on this I'm am completely confused :( all was going well aswell today because i had my new wheels put on
thanks in advance
chris
  • Replies 14
  • Views 1.5k
check the central locking pump
wouldnt even know where that was :s or wouldnt know what too look for lol
would the doors not unlock manually still though??
thanks mate
chris
open the boot an on the right hand side their is a panel remove it and their is a pump in their with a clear pipe coming off it and an electrical connnection going into it id start from their and check that the pump is working correctly, the pipe could be blocked or kincked, or the fuse for the pump could have blown
how can i check the pump is working correctly though?? just check the connection etc??
all looks normal on the pump....when i turn the key in the door it just stops...rather than continues turning to unlock :(
anyone...come on someone must of had this problem i am desperate
it could be the pump or it could of been the lock on the door catching and locking itself again
i forgot too put in the first post. if i am in the car and press the drivers side door locking pin down...it doesnt lock all of the other doors. just that one. iirc it used to lock both doors when i pressed the locking pin down from the inside. same as passenger side. and still no way to lock the petrol cap.
still desperate. could someone please tell me if when i put my key in the drivers side it should turn both left and right?? as its turning left and locking but not turning right and unlocking. and cant lock petrol cap. I'm stuck BIG TIME. looks like ill have to book it into VW.
the pump is still making the same sound and cant see nothing wrong with it but dont know what I'm looking for. it wont make no sound when i try to unlock it obviously as the key wont turn right. and its not the key as i have tried all 3 of mine
thanks
pleaseeeeeeee
Does the key lock the car from the pass side ok
yes mate locks all doors from both sides still...but unlocks none :( and wont lock petrol cap
so pas side locks all doors and fuel cap and drivers side wont do anything
passenger side locks all door not petrol cap and drivers does the same. neither unlocks any doors and neither locks the petrol cap
its weird i know. central locking pump still making a sound. had a quick look and couldnt see no defects but i wouldnt klnow what to even look for.
thanks
