Replacing Bulb In Centre Console On Mk4
:? i really am stuck here guys please can someone help
  • Replies 9
  • Views 1.4k
you are talking about which bulb?
If its the ones around the heater dials then it may well be the fuses, so check all of these first
If not then the panle surrounding them simply pulls off and a LED can be found behind
il check for the fuses however i cant see where the led is at all ?
morning bump.day off
please
Pull the middle heater dial firmly and it will come off. The bulb can be bought from Halfords.
PoloD.
Edited by PoloD
i have but i cant even see where the bulb goes :lol:
it has the white plastic bit and under that theres nothing
Cam easy way do what i do, Take your radio out pop your hand in the whole fill down and you should hit a White Bulb Holder it clips in and out its only a tiny little bulb now if u find it difficult try getting a flat head and poping of the Heater surround then you will find the holder behind
Sorry no that aint the same Mk4 are completely different the buld is held/attached by a big plastic holder which just clips on behind the heater, i would not suggest this way at all.
