How To Remove Bump Strips And Delete Rear Window Wiper On Polo 9n Mk6
Does anyone know if you can remove the rear wiper mechanism on a Mk6 as it is through the glass and not into the bodywork of the car...also are the bump strips up the sides just stuck on??
Edited by Gav9n
  • Views 1.5k
The wiper shoudl still come out it wont be bonded to the glass, go have a fiddle see if yu can get it to come out then go to halfords and buy a bung to fill the hole in the glass or go to a glass specialist and get soem black glass to fill the hole ;)
Sorry i dont know about the side strips
Cheers..gona do that now!! :-D :-D
hi mate. i just removed my rear wiper last weekend. it's really easy. all you have to do is remove the rear washer cover (just pull the plastic cap off) and then, after removing the inner trim, just unscrew 3 screws. easy. i just fitted a rubber grommet instead of the wiper. to remove the tailgate trim, just unscrew the 2 screws located in the inner handles, then pull the whole thing out. hope it helps...
as for the side strips, there are a couple of holes behind the rubstrips that would need welding and thus, respraying the door and rear panel :(
