Pollen Filter Leaking?
I think i've found a leak, it would appear that my pollen filter box is completely loose from both the fitting bolts rusting away.
The water is literally dripping from underneith the dash on the passenger side down the edge of the blower fan (marked in red) and on to the wheel arch, down in to the footwell.
Has this happened to anyone before? I was thinking about getting a fibreglass kit, cut away the rusted shit and fashion up a new surround as I'm pretty sure this is where the water is dripping in.
Most of it is mud though :oops:
Edited by Sp00n
  • Views 910
make sure the drains are clear at both ends of the scuttle as this is where the problems start, if you are using glass then make sure you cut away as much rust as possible and treat what you cant remove with some rust inhibitor
The drainage holes are completely fine, only ones I haven't checked are the rear sunroof ones because I dont know how to get at them but the front ones are fine.
