Easiest Way To Mend A Suspected Leaking Battery Tray
i drove through a VERY deep puddle last night and got a whole lot of freezing cold water all over my right foot which i think has come out from my battery tray ? haven't had time to check it out yet tho, I'm just assuming that's it.
so whats the easiest way of sorting it ? i can "bodge" weld but font have any equipment.
it really sucked as it was possibly the biggest puddle in the world, so i was dealing with the shock of having freezing cold water all over my foot, whilst trying to keep the car moving after hitting the puddle at about 40MPH - and my car is lowered 90/70 so i nearly stopped halfway through!
anyway, any suggestions ? thanks.
Or cheat ..
Cut the rusted area out and treat then either mould a glasfibre box of fab something up from a sheet of stainless ..
thanks guys, lol at "cheat" at fixing a leak :D
ill probably go for the firbreglassing I'm thinking - with a maybe on the welding, i dont know lol.
but thanks guys, much appreciated :)
glass fibre is easiest and cost about 8 quid for a full kit!
drop the tray down under the steering wheel ...you will see a rusty scab if its rotten
if you want to bodge...angle grinder both sides and make sure its all clean and dry the fibre glass both sides and a bit of paint
if its a huge hole then try and patch it first with the welder and use fibre glass to seal it
Dude thats sounds well bad!! it wouldnt happen to be the massive puddle on the cateram bypass would it?!?!?! i hit that yesterday at bout 40 and aquaplaned across it lol was nuts!!! but yea this sound like a perfict opertunaty to crack out my welder!!! :-D
