Mk2 Polo And Mk1 Golf Steering Wheels
will a mk1 golf steering wheel fit a mk2 polo?
thanks
will
  • Views 1.3k
if you have an early Mk2 coupe D reg or earlier itll be small spline so yes the steering wheel will fit, however if you have a late mk2 coupe, its be large spline, so the golf mk1 steering wheel wont fit unless you remove the large spline collar to reveal the small spline collar underneath
youll need a gear puller ideally, or a dremel to cut it off but youd have to be careful not to damage the threading on the steering column unless you fancy changing it!
i have a c reg so it should be alright
thanks
will
