G40 Predicament
My mate who does the work on my G for me has given up as he can't find the 2 wires to connect the vagcom up :cry:
We already know thanks to hayesey that we are looking for 2+2 interface which has two twin wire connectors clipped up behind the section of the dash under the glove box, but he's had no luck at all finding it.
So that's that and he doesn’t know what else to do
Which does leave me in a bit of a situation! I don't where to go from here, if I was minted and enjoyed getting raped up the ass then I would take her straight to VW but I'm not and I don't.
Background
16th January
Just wouldn’t start, won’t bump start either and got new battery as well as it ran flat twice this month
Still nothing
We got a new coil pack used different bolts as my mate said there wasn’t a spark
(but I doubt this now, as he asked for the old one back to try something out)
Spark plugs, oil, alternator, dizzie and all fuses are fine
Fuel is engaging and getting around the system
All these tests were done by my mate at my house
27th January
Called Green Slag up for recovery to tow it to his unit, everything including oil is fine but he tested 3 of the plugs and they weren't sparking so he didn't even bother with the 4th and arranged for the tow to take place.
My mates had it for last couple of weeks now and really can’t find the wires for the vagcom hook up for shit and has been trying various things and still nothing.
He said there was no oil in her, bone dry – Leak? This I find very weird as she was only topped up beginning off January when getting an oil buzz when going round a corner at speed from the tilt
The day that happened the next time I drive her I topped her up before hand, I even rang Jabba to double check the oil I had was alright as I’m blonde and I can have my moments
Plugs are no longer sparking
Dizzie is fine
Coil is pumping but only 12V instead of 20,000, if that’s right?
Immobiliser isn’t getting in the way as everything is engaging on tick over and I presume if there was a problem with it you wouldn’t be able to do that?
I’m close to giving up as I haven’t got the money but I don’t want to sell her and I don’t want to leave her stood for 3 years like the previous owner did as he’s had the same problems as me. She’s cursed, I’m telling you :disgust:
Where and what the fuck do I do now? :cry:
Any suggestions, help or advice appreciated :smirk: Apologies for the essay
p.s Please don’t reply if you’re just going to say summit c*ntish or cocky, I’m really not in the mood for a hormonal rant
  • Replies 74
  • Views 4.1k
I have heard of some that just don't have the diagnostic wiring in.
What is he planning on doing with the diagnostics anyway? The fault code system in a g40 is totally useless, far better to get a plain old multimeter and hook it up to various pins on the ECU connector to test for signals, show your guy this:
http://www.polog40.co.uk/forum/index.php/topic,214.0.html
The diag port is only any use for data logging sensor readings from the ECU as you are driving or trying to start etc... so if he only has a fault code reader then it's no use on a g40 anyway.
If he has something like VAGCOM then he can do the datalogging, but he'll have to make up his own wiring to connect to the ECU. All that is required is 12v, earth and a signal wire to pin 20 of the ECU (the fourth pin in the 2+2 connectors is unused). The problem is knowing which way round these go into the 2+2 connector on his VAGCOM machine. I will have a look at mine tonight and draw a quick diagram.
some are under the dash but have you tried the opposite side to the battery? I've found an odd plug in there before which i didnt know what it did.
right, found this:
The signal wire goes to the K-Line connection, L-line is unused on a G40.
This should be enough info for him to connect up to VAGCOM even if the car has no diagnostic wiring as long as he has some basic wiring skills.
I have found diognostic cables on the oppisite side to were the battery is located aswell underneath is it the "scuttle tray cover" ?? i dont know the name of the thing .. Were your wiper mech sits ..
I'd offer to have a look for you but i'm not sure where you are, sounds possibly like a wiring issue.
i know your not a million miles away.
I've made an FAQ now for sorting out missing diagnostic ports:
http://www.polog40.co.uk/forum/index.php/topic,1409.0.html
that sounds like the fog light loom connection to me, have you actually successfully connected to VAGCOM or similar using the connectors you found there?
The diagnostic ports are normally clipped to the side of the relays behind the dash board under the glovebox. They look a bit like this:
to me if there is no spark its a few things
dizzy (cap/arm/leads as well as dizzy)
coil
ecu
any alarm or immobiliser
i'd swap the top three with mate before getting a pro sparky to look at the alarm immob if you have one
*some useful shit*
woop!
finally something heducational on CP.
STICKY!!!!! 8-)
It is about time tbh.
I wasn't neglecting the G40 forum either btw, but I did reply on my thread to go further with these questions and it got missed :thumbsdown:
Just hard and frustrating for both off us, he's an utter legend, he does know what he's doing and looks after my baby so well when he has her, but when you haven't got the knowledge in certain areas, especially G's then you don't know where to start looking or know where to start. This guidance is excellent men, thank you very much.
Please keep your replies coming in and I will keep you updated. He's gonna have a bash at this :thumbsup:
Have the ecu relays been checked by the engine ecu?
Is the fuel pump at the back of the car priming when ignition is switched on?
Has your techy put the 2 identical plugs by the coil back the right way round when he swapped coils? (it doesnt go the way u would think it does!)
Has the dizzy actually been swapped with a known good one? Hall senders go wrong often and cause no spark from the king lead.
Not sure if this is the same or helps at all but i had a simular starting problem on a gt. Had an auto electrition out and he even missed it. After alot of messing about it turned out to be some kind of amplifier thats behind the coil that was stoppin it sparking.
can't remember whats been done/ changed. i'd personally be leaning to wiring or interrupted power supply to the ecu - either relay or loom related.
i'd check the voltage at dizzy and ecu relay with ignition on first.
most people replace both - infact new ones from vw are a single unit
Know those situations far 2 well. worth a check!
gd luck.
gd luck.
I'll go with the hall sender too.
Also, here's a good one, used to happen on the black G I once tampered with & the 1w unit that went in there.
The plugs on the coil (loom side) can become very slack & even start to burn out if you have been trying to crank for a long time. Simply replacing this plug or tightening up the pins in this plug can happen. I would check this on ALL conections, just in case it is simply something like this.
Otherwise hall sender.
If your struggle to test the hall sender drop me a line on MSN & I'll help you out..........other wise sell to me :-)
Hope this helps :-)
u dont need vag com it will more than likely tell u nothing useful atall.
thers not much to check really, do teh basic checks and work from thier.
spark - ecu, dizzy, coil, to them wiring. even with a broken dizzy u can still getb a spark but it wont run. just swap em form know working ones doest have to be g40 specific.
fuel - are u getting any? take pope off to a bottle and prime then crank to see if u are.
the its just dodgy alarms or immob, which tbh are piss easy to take out find wires are join old ones bak up. i had to do it the other day with no tools tok me 10mins to be running again.
i had the same kinda problem but it turned out to be dodgy ht 's
have you taken the plugs out dirt? where they covered in oil and burnt out looking
I'd go look at this. Both the metal ECU and Fuel pump relays next to the ECU can get water damaged over time. This gradually leads to poor connections, which is what happened to a loom of mine. I even think the faulty ECU relay lead to the death of one of my ECU's
Thanks for the replies, all been noted, he's free tomorrow night and having another go at her then :thumbsup:
Well when he come round mine he checked them and they were all fine and sparking, saw all that myself and it was a powerful spark and when green slag came out on my false breakdown they weren't but they still looked OK (I know looks don't mean shit on a fucked spark)
When he checked them at his unit I'm sure he said they're fooked and burnt out, I'll check that with him again :?
What causes a spark to burn out?
A dodgy connection somewhere or duff relays as said by people above :-)
Where abouts are you D16rrt?
Worcestershire
I had a problem similar to this with my GT... after a couple of weeks of swapping everything electrical and driving me mad, i finally found the problem to be a faulty multi-pin connector in the back of the fuse box. If you unscrew the fuse box and pull it free of the bulkhead, then disconnect the two multi-pin plugs from the rear of the fuse box. Have a look at all the pins in both sides of both connectors.
One of the pins in mine was crushed, looked like it had prob been like that from the factory, and was only just making contact.
If you were closer id lend you my vagcom adapter (2x2 into OBDII 16pin) , i know the ECU on the mk3's is basic but it can still point to certain non starter problems, mine showed the hall sender as being disconnected when i last broke down id checked everything else except for this opened the bonnet and the entire plug was hanging off.
