Help Please
I just drove my car about half way down the road and then the battery light came on nad my car felt really wierd to drive, like it was going to cut out at any second, i just about made it round a roundabout in second gear but the car just seemed to have a mind of its own, and the steering felt really light. I haven't driven it since all the snow so i dont know whether its to do with that or whether i need a new battery??!!
  • Replies 14
  • Views 1.2k
alternator belt snapped?
or slipping
Usually the battery light coming on means the battery isnt being charged, so maybe the alternator belt was slipping or something?
Chuck the battery on charge for abit?
Mine managed to die after i left the car for 3 weeks over xmas. Lucky i had my reciept still because the thing cost me £100 onlt 3mths ago and its supposed to last 4yrs :lol:
Mine ran flat when it hadn't been sat for a long period of time, so put it on charge and go from there :thumbsup:
Check your history, if it's old, treat you car to a new one that's what I did after it running flat 30 mins after being driven for a good 20 miles and needing to do a bump start in the snow :lol:
this is going to sound really stupid but what does it mean if the alternator belt is slipping?? will i need to get a new one??
Might just be because of the snow, if the belt gets water/snow on it it might cause it to slip.
I think the alternator charges the battery, so you could get it tightened? I'm probably wrong though :lol:
lol you probably know more than me! i could barly see out of my windscreen when i was driving bcos there was ice on the inside!!!grrr i swear its just one problem after another! :'(
:lol: Then don't start driving till it's defrosted you numpty :smirk:
lol i know, but my impatience gets the better of me and sitting there for 5 mins really does bore me :p
yeah the alternator charges the battery up
theres a belt powering it that is driven by the engine
if this belt has snapped or slipping, the alternator wont spin - so wont charge
get someone to look over it for you, neighbour or something
should be plain to see if the belts loose or missing
i have this same problem BUT its fine when the car warms up it only hapens when its cold
if its snapped the car should probably overheat and power steering would go aswell tho surely?
why would the car over heat if the auxilary belt had snapped? cant see a connection there? if the steering went light though i dont understand that either, id put that down to slippy road ha. yes youve obviously got to start with the things that dont cost, give the belt a quick twist to see if its tight enough. or there for that matter. if all still there and adjusted correctly get someone to check the alternator output and a drop test on the battry wont hurt. only other thing thats coming to mind is a bad connection on the alternator.
