Mice Living In My Dashboard :) And A Few Niggles
Not quite as the title states, but somewhere in my 6n dash (near the ashtray and electric window switches) it just squeuks constantly when I'm driving!! I figured that if i push down really hard on the blanking plate between the leccy window switches it almost stops. I'm thinking that somethings a bit loose? :S So how do I go about removing some of these bits to see whats going on? This has happened for as long as i can remember.
THEN - about a week ago i hit a kerb in the ice, straight on, no damage as took it to the garage and they said it was ok :D must have only been going about 10 mph. Since then.....
Its got a slight knocking noise when I'm going over a bumpy ish road, kind of sounds like rocking, but its obviously not the seats as I've checked them already :D
And thirdly, my sub was working fine, but since i hit the kerb its not been working. All the cables are still plugged in fine including the battery one. And everything in the back of the headunit is as it should be? Any ideas?
Would be a major help if anyone has ever had any of these problems as its making me want to sell up and get a Jeep Patriot company car :D, plus its obviouslys driving me mad!
Thanks in advance
Ed :lol:
  • Replies 12
  • Views 1.5k
the dash squeek will be no doubt the 2 screws located just below the window switches, in the bit where i throw my wallet and stuff, under there are 2 screws, and the bracket normally breaks, causing a squeek
Thanks DK, how do i go about fixing/tightening these screws? :)
its normally the actual holes that sheer off, birds has the same mouse, so its not top of my list of fixes lol
Definately mice.
Invention called a screwdriver.....lmao
And as for your sub, have you checked the earth on your sub?
Or Checked the main fuse, or the fuse on your amp?
The sub not working sounds more like a coinsidance tho tbh
I had the birds nest and squashed mouse too, I managed to fix it by tightnening the screws behind the cubby hole in front of the gear stick. You can see how I temporary fixed it in my thread lol
Clicky
ed_veedub are u a girl? well I'm guessing you re anyway love. not bin sid the sexist but uve got no common sense u girls have you. how can hitting a kerb cause the sub to stop working??? haha. i get ladies coming in to the garage saying since youve changed my brake pads my wipers dont work ha. not very professional but i just piss my self until they F.uck off ha.
MMMMMMM! Not such a stupid question really, Bit of a coincidence. The sudden jolt might have pulled somthing loose etc.
Sounds like you are a real helpful mechanic.
Genuine responses please. Especially you mr VR6 wannabe.
reyt then.
1st thing id go with everyone elses answer sounds good to me.
2nd thing id go with track rod end, ball joint or a wishbone bush, get car jacked up, check for play side to side and top to bottom. if theres some there, get someone to look in behind the wheel whilst you work the play. this will identify the offending item. might as well spin the wheel while your there and check for a wheel baring as a knock often causes a baring to fail. there will be a droaning noise if its gone or might also have slight play in it.
3rdly the sub thing, if you say youve checked all connections, thers a possibility of a possitive and negative arching out on each other when youve had the bang so therefor check the fuse. plus i know youve checked the earth you say, but they have to have a very good connection to power the amp suffiently. bit of sand paper on the metaljobs a good en. get a power probe on the job. cant go wrong then. only other option is to borrow a friend sub and amp. if it works in his car and not yours it obviously the wiring so at least you know where your batting. if it does work you are in trouble as therefor its you are equipment.
Clicky
yup thats them, they crack most of time, so a botch is needed!
Yeah a botch job is needed if they crack, luckly mine was still one piece. Simply give them a light tighten so they dont rattle around and then you're sorted :)
