Mot Failure
my car failed its mot today,reason was...offside stop lamp not working ..... windscreen washer provides insufficient washer liquid.... wish i had filled the bottle up and changed a 10p bulb lol :-( anyone else had silly complaints
  • Replies 30
  • Views 2.5k
I had a car fail due to a sticker on the sunstrip. Apparently you can only have the taxdisk showing on the screen!
Haven't used the garage since.
insufficient windscreen washer liquid? that's a new one on me! My g40 has passed the last two years with nothing but tap water in there. or do they mean it's not actually working properly? as in not enough fluid getting onto screen
I think he means his washer bottle was empty :)
Bit harsh doing a fail on that, most places I know'd either sort it, and charge a couple of quid, or tell you to sort it before driving away.
Cant the police do you for that if they stop you and check the car over, remember hearing this ages ago on the radio , i may be wrong tho
ah I actually read the post wrong! I thought he said he HAD filled the bottle up before and that it had failed because it didn't have soap in it.
what a jobsworth. Could have just poured a cup full in.
The last mot my brake bulb blew during the test, he said I'm going for a coffee, bulb rack is over there. :lol:
yes the bottle was empty,a local garage took the car for mot otherwise i would have raged about it. could be worse,had a car a few years ago and it failed because the door handle had snapped, SNAPPED BY THE TWIT THAT DID THE MOT
Before I sold my Rocco they failed it on the lack of a seatbelt plug they didn't even bother to look behind the seat for it..
mine failed cos it was to low!
Like you said its your fault. MOT tester is not obliged to mess with your car, and I'm glad that they dont.
Is that actually the reason?
I didn't think thats part of the test
Probably couldnt test it properly due to it being low.
Your an idiot if you have coilies and send your car on the floor to the MOT when you can raise it up.
We just fill the washer bottles up, change bulbs and check for seat belts normaly, saves alot of time without doing retests
I'm a tester and thats disgraceful mate. doesnt take 2 mins to chuck a bulb in and a drop of water in bottle does it. i take it they charge for a re-test. this is how garages get their £25 pound a test rule to work. YES its £25 pound for a test but when they fail it on something stupid and charge you for the re-test its not £25 pound anymore is it.
I've never payed £25 for a retest? 10 working days, bring it back within that time and its free. Unless it has failed on so many things that it required a full test again. More than 10 working days and it needs to have a full test again. I'm pretty sure it says all that on the failure sheet.
Edited by Tommo32
It's been 10 days before when I've taken mine in.
My understanding is that free re-test is at garage's discretion. The one I use charges a tenner for a re-test.
yup i'm that idiot! :D
altho the tester can take you car for a road test if its not able to get on the testing equipment but where i took it obviously chose not to do this lol!
LMFAO!!!
if you're car cant get onto the testing equipment then its seen to be too low. also if you have little or no suspension travel, its a fail :)
hehehehehehe oh well!
correct mate. its at the testing stations discretion. you are allowed to charge up to £52 by law for an mot. we charge £40 but re-tests are free. the 10 working days is the time before it needs a full test again. obviously in 10 - 14 days anything could happen to a car which could result in a fail the second time round, therefor a full test is required.
My first polo had all manner of problems with it but when I took it in the ONLY thing it failed on was the handbrake. It was only 13% working! Not a single advisory....
