6n Front Grille Support
How easy is this to remove and what tools would I need?
  • Views 750
very simple, pop the bonnet
then there is 2 scres above each indicator, i have noticed this can sometimes be a torx bit or soethime a little nut
uncrew and slide the indicators forward.
this allows access to the nut or screw which hols the grille rail to the wing. this s what holds the grille rail to the car but the actuial grille iitself is clipped into the slam panel!
this is held on by small plastic tabs unclip these and try not to break them as they can be very fragile
Thanks a lot mate, thinking of replacing and respraying black, might look alright next to metallic grey :)
