Oil Catch Tank... Anyone?
right, i have bought a bmc cda induction kit... but after a bit of research it looks like i need an oil catch tank to put my breather pipe into so my engine doesnt get f**cked up..
so has anyone got one they want to flog me or..
has anyone made there own and care to share on how they did it?
or actually what has everyone else done with there breather pipe?
much luv ....lynx
You could do the old "pipe into a plastic bottle" trick but it's really not
the best thing to do,or you could buy one.I got mine from here... http://nfauto.co.uk/oil_catch_tank.htm
There are a few different sizes on there to choose from.
got mine off ebay - £30.
Still haven't got it plumbed in tho after all this time!
so what have you done instead then ?
i attached the catch tank to the bulk head with some cable ties and then discovered that the inlet for the tank was alot smaller than the pipe that was going to connect to it. ended up letting the gunk go everywhere and i jet blast it once a week with morrisons jet wash!
I've got an Ebay one. It came with a pile of different sized inlet and outlet fittings. its mounted to the bulkhead, but i havnt botherd fitting the outlet pipe so that just go's to air.
mine will probably be the same if i can be bothered to plumb it up in the cold!
