Sub's + Amps
hello clearing out the garage of old audio stuff i got, prices are a rough guide
10" Alpine Type R - with box £80
12" Vibe - with vibe box £120
15" kicker - in custom enclosure for a MK2 golf but can fit in others £140
also amp wise
Orion D2400 £180
Frenzy cheap amp good for 6 x 9's £20
and i think i have a vibe monoblock amp £50
give me a text on 07858512020 if interestedor Pm me
  • Views 388
bump
I'm intrested in te alpine sub mate, can you get pictures and pm on more details if thats possible dude?
heres a link and spec http://images.google.co.uk/imgres?imgurl=h...l%3Den%26sa%3DN
Big and bad and built for heavy-duty sound, Alpine's SWR-1042D 10 inch subwoofer delivers high-impact bass that you can hear and feel.
Description
Big and bad and built for heavy-duty sound, Alpine's SWR-1042D 10" subwoofer delivers high-impact bass that you can hear and feel. Alpine has taken previous generations of its SWR Series subs and added the hottest technology for ground-pounding power and superb accuracy.
The pulp cone has been reinforced with KevlarB. (the material used in bulletproof vests) for extra rigidity, so it won't buckle under hard play. A rubber surround helps to maximize cone travel for deep bass, while withstanding the decay that can destroy a speaker. A redesigned thermal management system and aluminum airflow motor cover shed heat quickly for efficient operation and better power handling.
The 2" dual 4-ohm voice coils are big enough to handle lots of power while offering system wiring flexibility. The tinsel leads are virtually unbreakable b they're woven into the dual progressive Nomex spiders. An aluminum diecast frame provides a secure, non-resonant housing. The SWR-1042D is designed for use in sealed or ported enclosures.
Note:If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Features
10" subwoofer with dual 4-ohm voice coils
Kevlar reinforced pulp cone with Santopreneb" rubber surround
cast aluminum frame with perimeter venting
frequency response: 26-600 Hz
power handling: 200-500 watts RMS (250 watts per coil)
peak power: 1,500 watts
sensitivity: 83 dB
top-mount depth: 6-7/8"
sealed box volume: 0.5-0.8
ported box volume: 0.6-1.3
* *Sales package content and specifications may vary and might change without notification.
Specifications
Impedance : 4 ohms
Cone Material : Kevlar Reinforced Pulp
Surround Material : Santoprene Rubber
Sealed Box Volume (cubic feet) : 0.5 - 0.8
Ported Box Volume (cubic feet) : 0.6 - 1.3
Port diameter (inches) : 2.5
Port length (inches) : 9.8
Free-Air : No
Dual Voice Coil : Yes
Sensitivity : 83 dB at 1 volt
Frequency Response : 26 - 600 Hz
RMS Power Range (Watts) : 200-500
Peak Power Handling (Watts) : 1500
Top Mount Depth (inches) : 6 7/8
Bottom Mount Depth (inches) : 7 11/16
Cutout Diameter or Length (inches) : 9 1/8
Vas (liters) : 20
Fs (Hz) : 33
Qts : 0.53
Xmax (millimeters) : 18.2
Kicker sub and I think it's the Orion are sold to me
