Small Numberplates? Legal?
i got given a smoothed bootlid (6n) with a small numberplate recess but I'm not sure how i go about getting the numberplate for it and is it legal?
I'm guessing not. but help would be appreciated.
Thanks.
Amy.
  • Views 1.9k
as far as I'm aware it isnt legal, I've got some small ones on mine atm & I'm geting the recess done to size.
just have to face the risk of geting pulled, butt its up to you if u want to risk it or not :)
long as its correct font and letters are spaced n sized correctly i cant see a problem. :nod:
david.
so they must be illegal then, unless i get a personal plate (like mikes) with about 4or 5 letters/numbers.
it says there that you have to have a space of 11mm between letters so it wouldnt all fit onto a smaller than standard size plate.
11mm between letters yes, so you can legally cut down 5 digit plates for example, but not really 7 digit plates as you'll be squeezing the letters together and reducing the 11mm..
Just go on www.platemyride.com and have a play with the different sizes and see what fits.
