Audi 256mm Conversions For Mk1-3 Polos
Got two 256mm audi conversions up for sale that will fit mk1-3 polos for some uber braking
consists of
Lucas 54 Calipers (One set in the silver, and one set in red)
Audi Carriers
Pads
Solid 256mm Discs in vgc
Braided Hoses
200 pounds per set
postage 12 pound by courier
cheers
saf
Edited by grungeisdead
  • Views 419
pm'd :-D
bump
hey
is it a easy job mate ??
piece of piss, helps to have a mate when you bleed the brakes, but an auto bleed kit but gumson is perfect for the job on your tod and about a tenner
drain brake fluid whichever way you feel best
remove two brake flexis at the front
undo the two 17mm iirc carrier bolts, remove caliper and carrier and pads.
remove disc held in by a small locating screw
fit new disc and screw
fit caliper/carrier/pads ensemble over disc
bolt up the two 17mm bolts into the carrier
screw flexi into caliper
connect flex to solid brake line
new brake fluid
bleed
job done
