Removing Rear Wiper On Mk2 Coupe
Those of you who have removed the rear wiper from a Mk2 Coupe, what did you use to plug the resulting hole in the glass?
I haven't removed it yet, but I want to get something to plug the hole ready for when I do so I don't drive round collecting rainwater.
  • Views 2.8k
Dan... you could use one of these
:-D
you can probably get a rubber gromit from halfords and perhaps use some rubber sealant or something like that. Or just masses of Duck Tape! :)
Any other ideas or suggestions?
I actully filled mine with body filler, smoothed it off then masked it n sprayed it black. looks miles better than a rubber gromit. also venom to perspex flush grommits, but i think their expensive.
Trim a suitable piece of glass on a stone wheel,then use windscreen repair to bond it in place.
Never tried it myself,i should add..
my grommet has been in there for the past year with no probs. if you remove the rear trim planel from the boot lid it is possible to pop the grommet out and open the boot with a long stick, be warned.
