6n Squeeky Dials
hi guys, my dials squeek really badly and have found hte problem to be the flap behind the steering wheel which goes under the dials and goes up and down when you adjust the wheel, anyone else had this problem? and how did you fix?
  • Views 871
Yeah, also having this problem, can get quite annoying.
Possibly remove it, and bend the spring under it so it won't move as much...... ?
To remove it's only like 3 phillips screws underneath.
the best way to do it is press the black plastic at the bottom of the dials upwards, it wont stop it forever but it'l stop it for a while.
or smack it till it stops annoying you :)
Are you on about the black plastic flap just underneath the dials? if so, its just pressed on with C clips, simply give it a tug and it'll pop off :) Had to remove mine as it had snapped on one side, sorted it now.
cheers guys, yeah that crappy plastic flap, dunno what its for!!!
