Urgent Coilover Help!
hello me and my dad r fitting a set of ta technix coilovers to my 6n polo
we have put the back ones on but in doing so the thread at the top of the coil where it comes through into the boot isnt long enough to get the washers on what should we do, it can get all the nuts on but not the golden, plate like washer?
  • Replies 10
Helped fit these to my mates mk4, the coil probably isn't sitting properly in the turret, shift it about and you get the full thread through
cheers but the thread on the top of the coilover that goes through the hole wasnt even long enough to get all of the original nuts and washers on when it wasnt on the car. It doesnt make sense we could fit them fine infact we r gettin quite quick now lol its just the washer won't go on the top with all the nuts on and therefore my dad doesn't think its safe. It also doesnt make sense as to why the company didnt just make it longer???
Before you started, you should compress the coilovers as much as possible by pushing down on them then wind the nut down as far as possible, therefore more of the tread is showing on top of the coilovers. Also when you sat them in the hole did you get a jack and try and raise them as far as possible into the hole.
yer me and my dad did compress them as much as possible and it was jacked up and we could easilly get it through just wasnt enuf thread to start with, could there b a fault with the coilovers or do i need that gold washer on top?
We (me and kwijibo_coupe) had this problem and had to reuse the spacers from the original shocks rather than the ones that came with the coilovers.
but surely if the coilovers were right in the first place then u wudnt need to do this?
also wen taking the new spacer off which me and dad are thinkin about doing that or replacing the nut with the original as its smaller, the tension in the spring could be quite considerable?
It is odd, we never had the problem on the last set of TA coilies he bought I don't think
I'd always use new nuts
There's fuck all tension in the spring if you wind the spring retainers down
I think TA technics have changed the design of the coilover over the past year which means you have to use most of the top of the old suspension. When putting it all on if you have the adjuster ring all the down at the bottom the spring will be under very little tension and you should end up with alot more thread at the top with alot less effort.
Then adjust the rings to suit your needs.
the suspension coil is to the very bottom the only thing i can think of doing is to either use the old spacer or nut as it just doesnt fit, not sure why they have made it like this pretty stupid tbh, cheers for your replys going to get up early and have a look tomorrow. :)
Thats exactly what you will need to do.
