Do I Need To Lacquer?
I've got quite a few rusty spots that I want to sort out on my MK4.
I'm going to tackle it with some rattle cans. Will I need to Lacquer afterwards?
Also any tips on prep etc would be great.
My plan of attack so far is:
1) Sand/wire bush down the rusty areas to bare metal
2) Apply some rust inhibitor stuff
3) Body Filler the bits that need doing
4) Sand down the filler with wet/dry paper
5) Apply Primer (how many coats should I do?)
6) Apply Paint (how many coats should I do?)
7) Apply Lacquer (again how many coats should I do?)
Any advice you could give me would really help.
Edited by mrtank
  • Views 853
Sounds like a plan...
ok you want about 3-5 coats of each
yes lacquer you will need to bring out more of a shine and that protective clear coat.
Where are the rusty spots excally? just I have got some round the 1 of my windows that I have sanded for now but its gone blue?
Whats this rust inhibitor stuff like? never tryed it, ill get some 2morrow
Ok so hope i helped
...Whats this rust inhibitor stuff like? never tryed it, ill get some 2morrow
I think it helps stop the rust in its tracks. It chemicallty converts the iron oxide to a stable iron compound. I've no idea how good it really is, but I do know I did a quick touch-up job to a patch of rust on my 1st car almost 4yrs ago and it quickly came back after about a month. So I re-did it however the second time round I applied this stuff and it seemed to work. I'm quite sure your meant to remove all signs of rust however (back to bare metal), I'm only planning on using this stuff as a fail safe.
Cheers for the advice m8; My rusty spots are mainly at the bottom of the doors.
