Aerial Relocation
ok so i removed the aerial from the wing and wanted to move it to the roof so today i thought id get on with it after putting it off for so long
first this was to get the rooflining off
looked around for a heat gun but couldnt find one so the next best thing was used (hair dryer)
takes a while to heat up the vynal but it workes well i thought you just have to take it slow peel back the roof lining a bit at a time then just above the stitch line on the roof lining there is a bar that holds the lining up unclip this by pushing it towards the front of the car
now i had the lining down i then set to working out where i wanted the aerial to sit then marked it with a perm pen just using a small dot if you get it wrong t-cut will remove it then its the bad part lay a bit of tape on the roof masking tape is best so you can see the mark you made throught it (i used black tape as this was all i had to hand reason for it is to stop the drill bit slipping and scratching the roof
now you have your hole in the roof grab the aerial ( i used a small amount of silicone sealent on the bottem just to be safe ) place it through the hole and tighten from inside the car just nip it tight dont over do it !!!!
i found it best to run the wire down the rear pasenger pillar of the car then all the way to the head unit i needed an extention to get it there but some aerials come with longer wire i guess i also had to remove the pasenger rear door card or you could just tuck it under the carpit
then it was just a matter of getting it all back together best way i found of getting the lining back in place was spray glue pull it tight then hey presto done
worked well for me hope it helps you guys/gals
  • Views 760
some pics not the best but hey
brave man :thumbsup:
thanks dude but it was easy just have to take your time thats all
