Mk3 Gt Conversion, 4 Speed ?.
Pretty sure i'm going for a GT conversion on my MK3 1.0 Genesis, the conversion comes with the 5 speed box but what would be the advantages/disadvantages of using the 4 speed ?, obviously top speed will be lower and motorway cruising will be noisier but i dont do big motorway miles and when i do i'm happy to sit at 70 :-D
Has the 4 speeder got shorter 1st 2nd and 3rd ratios ?, is it stronger or weaker ?, how does the change compare to the 5 speed ?
  • Views 646
Disadvantage of 4 speed, your engine screams everywhere you go after passing 60 and motorway driving is terrible.
Hence why people go upgrade to a 5 speed not downgrade to a 4 speed. The GT box has closer ratios than a standard 5 speed polo box so keep that tbh.
I was given a stock Kia Pride as a run around while my sleeper pride was being repaired and a mate had a Mazda 121, same car same engine but i had a 5 speed his was 4, doing 70 sounded as if his engine was going to drop out or blow up, 5th gear was useful.
Edited by Cymro
In terms of ratios, a GT box is pretty much like a 1 litre 4 speed, but with another gear after 4th.
dont put a 4 speed in it you will be disappointed quick on acceleration but shite when you go long distance or motorway driving
jonny
