Removing Rocker Cover
Is it as straight forward as it seems to remove the rocker cover on a Mk4 Polo? What tools will I need and will it affect anything else if I take it off? Cheers,
Dan
  • Views 954
8v? Or 16v? If it an 8v just undo the 3 screws, (star key) then take oil cap off and it should pull off might be abit stuck but should come off. It's possible you may need a new gasket if it gets damaged. If it's a 16v then I don't know
What engine size do you have? The 8v rocker covers are really easy. 3 (cant remember the size) allen key bolts and the cover just lifts off. Make sure when you put it back on the gasket is sat right on the head otherwise oil can leak out
Cheers guys. It's a 1.0L 8v so I'm guessing it's pretty easy like you said, I just don't wanna mess anything up in the process..
