Mum's 9n Polo Problem
Evening everyone. Got a problem with mums 9n Polo. Car been getting condensation and smelling recently and we found where it has started from. We found a shite load of water under the spare wheel in the well of where it sits and the water has made its way onto the side carpet and soaked into it (most probably when the car turns corners and water has thrown itself up the wheel well and splashed everywhere)
There are about 5,6 rubber seals on the floor of the spare wheel well. When u look under the car u can see a couple of them are wet and so we're thinking the rubber seals have worn out? Could we be right to assume that?
Anyone else had this problem before and also any idea how much these lil rubber seals cost?
Thanks, hope you're all coolio!
Jay
  • Views 769
I had the same problem with my mums golf. The boot floor and rear footwells had turned into lakes!
The water went through the sunroof and into the drains, which were blocked, so it was running into the car. If your car has a sunroof, this is likely the problem and its easy to put right.
There are little "teats" ;P around the car where the drainage from the sunroof runs out. However theese become blocked after time and need cleared. In my golf they we situated just close to the hinge of both front doors and under the back bumper. There were four in total.
Hope this helps
zach
Edited by zak33_33
hi zach thanks for the reply mate. unfortunately my mums car doesn't have a sunroof :(
Have you checked if the rear window washer jet works? Quite common for the pipes to pop off in the boot. Its unlikely to be the bungs/grommets in the floor, they are wet underneath because the water is getting out through them (gravity and all that! lol)
Also check the seal at the bottom of the aerial base, this perish's and water gets in through there to.
to get rid of the smell, get a litter box with it with litter from cat litter bag, and it should soke up the moisture
