Rear Wiper Jet Not Working
Hi people,
As above, the rear washer jet on my car packed up a few weeks ago - now when I want to use it I hear it trying to work but get no water.
Anyone else experienced this and if so how did you resolve it?
Cheers!
Matt
  • Replies 14
  • Views 1.6k
Hi people,
Cheers!
Matt
check under the washer bottle that the pipe is still connected if not just plug it back on if it happens again black tape the pipe an connector
Could also be a blocked jet if the pipe hasnt come off
Cheers lads Ill check tomorrow and let you know
well what was it then ?
Perfect excuse to remove it IMO 8-)
get it working first ,and then remove it ..... :-D
the pipe could have become disconnected somewhere between the bottle and the rear.
if you take the plastic cover off from the inside of the boot lid check the connections there.
mine was disconnected above the c pillar which was a pain in the ass. whenever the button was pressed i had a flood of water in the boot - not good!!
good luck in getting it fixed!
fill the washer fluid tank up, when it gets low the rear stops working before the front.
Didnt get chance this weekend - I've filled the washer bottle up to the brim 3 times and its still hasn't worked.
I would take it off but I actually find it useful !!
However if it is disconnected in the c pillar then I might just do that !
Edited by polocsv
yep look through the car looking for damp patches :D mine was spraying washer fluid all over my 1500w sub amp... not good!
haha yeah my boot was soaking and i always wondered why. but i didnt have a sub in there - did blow fuses on my power supply and boot light though!
The worst is on mk4 golfs - In the winter the rear washer jet freezes and the pressure of trying to pump fluid through it pops off the tube from the jet - this sprays fluid into the boot lid, however the washer jet is directly above the sensor which tells the alarm if the boot lid opens; this makes the alarm go off every 20 minutes or so and can only be fixed by replacing the boot latch mechanism or unplugging the alarm sensor - it's a right bloody pain! In fact anyone reading this with a mk4 golf - go buy some araldite and plastic-weld the washer tube onto the rear washer jet to avoid this problem!
H
I've got the same problem. Makes me think isn't this a design fault with VW hatchbacks??
Can anyone advise how I can solve this (without having to go to the dealer and getting ripped off!)? I know the back panel is secured with screws in the two handle areas on the inside of the lid but popping that panel off is tough. I don't to force it and end up breaking it. Any advice would be much appreciated (oh, and it's a mk7 if that helps in any way).
cheers
i dont know anything about mk7s but in my mk5 there was wee metal bits around the edge behind the ajoining plastic panel it took a bit of wiggling and pulling but i don't think it'll break. I managed to get it out fine.
Good luck!
Lisa
