Roof Liner Help
I'm wanting to re-wrap my roof liner in black and white check material, I'm not sure how to remove the roof liner to do it, any help would be great! thanks :D
  • Views 1.3k
bump...anyone?
I'm trying to do the same with my 9N3!! I cant find help anywhere!! I have a plan though, I'm gonna take the whole thing out, sand it down and use spray adhesive......... from there i make it up as i go along! I'm getting the material next week and ill let you know. I see someone putdown a blog about blue camo roof lining so have a look at that it might help. Shame there is no definitive guide to roof lining.
my best mates mum is doing mine
my mk3 one came out dead easy and in one peice once the back windows were out but she plans on using wooly stuff that will be fabric bonded to the reverse of my red and black leaterete and then the wooly cushiony stuff glues to the bare roof with extra strong double sided carpet tape and help from the roof lining rods (they slide inside the wooly stuff for extra support)
after all that its just a matter of triming the edges and tucking them into the sills.
tips: make a template out of an old matress cover-so you know howmuch stuff your going to use
dont skimp on the wooly stuff (soundproofing) or you may regret it
defenatly get some QUALITY double sided stickey for obviouse resons
good look guys
i am doing this as well but i have nothing in the car just dash and roof but i have a prob as i cannot find out how to take off the sunroof winder lol.
all u need 2 do is take off the seatbelt side pans and then the boot pans then once they r off there is 1 more across the back of the roof then just pull it think it is just stuck on every thing els holds it up
going by the picture its a mk4 in question?
if so remove grab handles all round, sunvisor clips and mountings, A,B,C pillars and the trim above the boot opening and it should simply drop down
