Sticky Horn?
after 10 mins of trying to figure out whats making my horn stick on, found its the steering wheel.
turn it 45 degrees and it turns on, so its obviously disconnected atm.
but i cannot for the life of me figure out whats making it stick.
its a polo saloon w/ a coupe s steering wheel.
back to standard..?
  • Views 764
if the switch system in the wheel is the same as the mk3 then could it be the wire's are to short causing it to pull the switch in.
Mine have packed up entirely again, relays clicks bugger all happens :lol:
hmm... happens when the switch is off though (centre of the steering wheels out), but when the entire wheel is off its fine.
